Garmin G3X or G5 Autopilot installation
tonyvaccarella
PostPosted: Sun Aug 16, 2020 8:46 pm    Post subject: Garmin G3X or G5 Autopilot installation Reply with quote
Hi all,
Im in the process of installing a pair of Garmin G5 instruments (Attitude Indicator and DG) and a Garmin Autopilot. Part of the configuration process is to enter the gains for the Roll and the Pitch servos. This is conducted by doing a number of test flights and adjusting the gains until the autopilots seems to behave properly.
Have any Europa builders installed a Garmin Experimental auto? If so, would you mind sharing your configuration data to overcome the need to conduct a lengthy calibration process?
Best regards,
Tony Vaccarfella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
