Ground LC3C controllers
PostPosted: Mon Jan 11, 2021 2:16 pm    Post subject: Ground LC3C controllers Reply with quote
At 03:47 PM 1/11/2021, you wrote:
The wiring diagram indicates ground the #7 pin from the alternator controllers to the engine block. The firewall side 24 tab ground block is close by. Is there a reason the controller ground should go to the engine block rather than the 24 tab ground? Does it matter? (It's all tied together in my composite.)
Dan
To the FIREWALL GROUND BLOCK . . . NOT ENGINE
out of that stuff?"
