		| Author | Message |
		| europa(at)pstewart.f2s.co Guest
				|  Posted: Wed Jul 26, 2006 8:00 am    Post subject: wiring |   |
				| I have another couple of questions relating to wiring:
 1. The wiring diagram in the build manual has a alternator output
 switch (capable of taking 25A). Does the OV crowbar mod take the
 place of this switch?
 2. In a 914 fit, one of the fuel pumps is wired directly to the
 alternator/regulator output. In the event of a regulator failure, the
 OV mod prevents the runaway voltage frying electrics/battery. Why
 would it not fry the fuel pump and if it would,  why not wire the
 essential fuel pump directly off the battery - would you not then
 have  a working pump to get the aircraft down.
 Or have I got this all mixed up again
 Paul
 G-GIDY
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Wed Jul 26, 2006 9:58 am    Post subject: wiring |   |
				| Paul & Gilles, I missed the beginning of this thread, but I am impressed
that if you wire your 914 fuel pumps according to the diagram that came from
 Europa with mine, then you can switch off main switch and alternator switch
 and one pump carries on - supplied directly from the alternator. It wouldn't
 matter if the rest of your electrics were totally fried. Alternatively you
 could have a blown alternator and power the other from the battery with the
 alternator switched off, and inessential electrics switched off.
 I went some way to proving the former point when I managed to
 switch both Main & alternator switches off with my left trouser leg (having
 lifted my leg to replace my pee bottle under the L thigh support!), over
 rather inhospitable countryside near the German/Czech border - nothing but
 forest. All the dials were blank but the plane went merrily on while I
 sorted it out.
 The latter situation is a bit like that I found myself in having
 just departed the Belgian coast for Dover, and the regulator packed up
 completely. The essentials (a radio and a fuel pump) took very few amps and
 I readily persuaded myself that my 16 amp/hr battery would get me to the
 other side, which it did and more. So you do have electrical redundancy in
 the sense that you only need either the alternator or the battery to be up
 and running.
 Regards, David Joyce, G-XSDJ
		| Back to top |  |
		| nwcmc(at)tiscali.co.uk Guest
				|  Posted: Wed Jul 26, 2006 10:11 am    Post subject: wiring |   |
				|  	  | Quote: |  	  | I have another couple of questions relating to wiring:
  	  | Quote: |  	  | 1. The wiring diagram in the build manual has a alternator output switch (capable of taking 25A). Does the OV crowbar mod take the
 Effectively yes. The main purpose of the switch is to be able to isolate
 the PM generator (alternator) from the rest of the system in case of a
 problem. It should normally be left connected to ensure that some load
 is created as no load can apparently cause a problem for the regulator.
  	  | Quote: |  	  | 2. In a 914 fit, one of the fuel pumps is wired directly to the alternator/regulator output. In the event of a regulator failure, the
 The fuel pump load is normally sufficient to keep the regulator output
 within limits. If the regulator goes totally out of control it needs
 isolating from the rest of the system. Although this would mean one of
 the electrical pumps going off line the other will still provide
 pressure. Conversely should the battery or associated switches or
 busbars go offline the generator will always have a direct connection to
 one of the pumps. Thus any one failure should mean that either the
 battery or the generator should be able to power at least one pump. Your
 suggestion does not cover the case of total battery failure.
 Nigel Charles
		| Back to top |  |
		| m.j.gregory(at)talk21.com Guest
				|  Posted: Wed Jul 26, 2006 11:14 am    Post subject: wiring |   |
				| Paul,
 While I agree that the principal reason you might wish to switch off the
 alternator is because of an overvoltage malfunction, which would be taken
 care of by the crowbar circuit if you fit this, it does serve also to
 isolate the fuel pump that is supplied from the alternator circuit when you
 put the battery master on.  This means that you are not driving this pump
 when the engine is not running, e.g. during pre-start checks, programming
 the GPS, etc.  It also provides an easy means of checking that the
 battery-supplied pump provides pressure prior to starting.
 I note that the latest Z-16 diagram for a Rotax 912/91 circuit from Bob
 Nuckolls AeroElectric Connection shows his crowbar circuit driving a relay
 to disconnect one of the yellow leads connecting the raw alternator output
 to the regulator.  The purpose of this may be to stop the alternator from
 frying a faulty regulator.
 Mike Gregory
 Europa Club Safety Officer
		| Back to top |  |
		| paul.mcallister
				|  Posted: Wed Jul 26, 2006 11:52 am    Post subject: wiring |   |
				| Paul,
 I am with Nigel and Jos on this one.  The circuit proposed by Europa (in my
 analysis) falls in the category of "crude but effective".  I can't recall if
 the circuit shows a CB or not, but I have a pull able circuit breaker on the
 panel in case I do need to shut all fuel pumps down.
 I have tested this out by disconnecting / disabling the battery/main
 contactor  just to prove to myself that the pump will continue to run.
 I did get a real world test when I was hit by lightning, my Kilovolt main
 contactor was destroyed and for a while the only power to the pump that was
 being supplied was via the direct connection of the alternator to regulator.
 I heaved a big sign of relief when I turned on the secondary Ebuss and it
 actually worked, actually I heaved a big sigh of relief for a lot of
 reasons.
 Paul
		| Back to top |  |
		| rparigor(at)suffolk.lib.n Guest
				| Hello Paul
 To answer your 2 questions:
 1) See page #4 of the Europa Club Over-voltage Crowbar Unit Installation.
 Figure #2 is for Permanent Magnet which is what you want. The OV crowbar
 mod does not take the place of the alternator output switch. It essential
 puts a relay in series before the 30 amp slow blow fuse. If over-voltage
 is detected, the crowbar unit will crowbar (create a short)  placed on the
 5 amp circuit breaker and pop and take the Rotax Alternator (really a
 generator) off line.
 I chose to use Eric Jones solid state OV protection on my Rotax generator:
 http://www.periheliondesign.com./lovm.htm
 2) I don't absolute agree with Gilles, if wired as per Europa, if for any
 reason battery is not putting out, 1 pump will run off of generator
 (provided it is excited, which would have happened upon start up), that is
 why there is no switch to turn it off?? If generator fails, you can run
 the other pump off of battery. As far as turning off fuel flow in event of
 emergency, turn off the fuel selector (not good practice to run a pump dry
 if you can avoid).
 Gilles has 2 batteries on his 914 install which in my opinion is better
 than Europas redundancy. That said I think if you are only going to have 1
 battery and only internal generator, following Europa is not such a bad
 way to go. I personal would put a switch on pump #1 and some sort of light
 or warn to show it is off, that way you can test output of pump #2 more
 easily.
 I went with on my 914 with a SD20S as primary alternator with LR3C
 regulator with built in OVP and Rotax internal generator as second or
 standby with Eric's solid state OVP. Schematic loose based on Bobs Z13 /
 8. 1 pump main bus and 1 on endurance bus. I also have a total loss 13
 cell 2200mA NiMh battery pack in the starboard headrest, in under 10
 seconds can run a pump on it (redundant wires to this connector), or if
 lost main battery and main alternator, can excite internal rotax, or run
 endurance bus from it. Very light, yet can probably output enough to start
 the 914! Model guys draw 150 amps plus from these cells.  When soaring,
 and main battery fails open upon restart, in 10 seconds and can run prop
 off this battery to air-start after I take main alternator off line, if no
 time to cycle prop and not enough altitude to dive can probably restart
 form it, then put rotax internal on line (Rotax is much happier than SD20S
 ND with no battery.
 More than you asked for.
 Ron Parigoris
		| Back to top |  |
		| europa flugzeug fabrik
				|  Posted: Wed Jul 26, 2006 3:01 pm    Post subject: Re: wiring |   |
				|  	  | europa(at)pstewart.f2s.co wrote: |  	  | In the event of a regulator failure, the OV mod prevents the runaway voltage frying electrics/battery. Why would it not fry the fuel pump... |
 I rather believe we will have a dangerous situation if OV protection removes all load, and thus sends full, high-voltage regulator output to one of the 914’s fuel pumps.
 Better to let the OV condition exist, and warn with an aural or visual alarm, plus a voltmeter.  If we have say 10A load on the bus, I doubt the system could supply more than 3-4 extra volts, which isn’t going to hurt anything if for not too long. Just turn everything on and reduce RPM until volts fall to a level the battery can tolerate for a while, like 14.7V.
 Unless we’re too lightly loaded on the bus (few goodies), OV protection won’t do  much.  The AC wiring from the engine is also the place to install the OV relay, but simpler than that is just a switch next to our voltmeter and warning lamp.  If lightly loaded, and we want to just cut back alternator output, a pair of 50W resistors in parallel, value selected to douse the watts we need to pull the volts down, should work.  Switch “unbypasses” the resistors in the AC circuit.  This would not require us to have only battery keeping the pump running.
 Fred F.
		| Back to top |  |
				|  Posted: Thu Jul 27, 2006 12:31 am    Post subject: wiring |   |
				| Thanks all for the discussion.
 As a follow up.  What sort of switch have folk used to switch the
 alternator/regulator  output?
 Paul
		| Back to top |  |
		| ami(at)mcfadyean.freeserv Guest
				|  Posted: Thu Jul 27, 2006 2:21 pm    Post subject: wiring |   |
				| Honeywell locking toggle (i.e. the type where the toggle has to be pulled
out against a spring before moving).
 Duncan McF.
		| Back to top |  |
