Ragwing Ultra-Piet
Goto page Previous  1, 2, 3 ... 11, 12, 13
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
boyerjrb(at)comcast.net
PostPosted: Fri Mar 26, 2021 6:42 am    Post subject: Ragwing Ultra-Piet Reply with quote
Paint looks good, just needs more. I like the yellow. Cheers, Jim
On 03/25/2021 6:18 PM cdlwingnut <lee_chad(at)hotmail.com> wrote:
getting too low on the echo bond glue to start the top fabric of the right wing. So while waiting for an order of it I made a trip to sherwin williams for some paint. After testing it on some scrap fabric I felt brave enough to brush a coat on the vertical fin. I plan to brush the first coat on to get it into the fabric then spray the second and if needed the third coat on.
http://forums.matronics.com/viewtopic.php?p=501101#501101
http://forums.matronics.com//files/20210325_150316_resized_636.jpg
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
cdlwingnut
PostPosted: Fri Mar 26, 2021 3:08 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
did some wet sanding today then got the elevators primed.
 Filesize:  223.63 KB
 Viewed:  268 Time(s)
cdlwingnut
PostPosted: Tue Mar 30, 2021 4:41 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I did a little bit more wet sanding on the elevators one has two coats of primer now and is ready for some color the other only has one coat on it.
The echobond came in as well so I worked late and got the fabric glued onto the top of the right wing. A few passes of the iron and it will be ready for rib stitching and tapes.
 Filesize:  229.38 KB
 Viewed:  251 Time(s)
cdlwingnut
PostPosted: Wed Mar 31, 2021 3:27 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
And the fabric is shrunk
 Filesize:  197.94 KB
 Viewed:  239 Time(s)
cdlwingnut
PostPosted: Fri Apr 02, 2021 1:41 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
more rib stitching. one rib with the long strait needle one rib with the curved needle. the ribs with the compression braces have to have the curved needle used since they block the path of the long one.
 Filesize:  130.92 KB
 Viewed:  222 Time(s)
cdlwingnut
PostPosted: Mon Apr 12, 2021 5:26 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
still working on the rib stitching got all the ribs I can use the long needle on done and all the top of the ribs i have to use the curved needle on
 Filesize:  151.29 KB
 Viewed:  115 Time(s)
PostPosted: Tue Apr 13, 2021 8:23 am    Post subject: Ragwing Ultra-Piet Reply with quote
Looking good; makes you think you will have an airplane soon.
http://forums.matronics.com/viewtopic.php?p=501381#501381
http://forums.matronics.com//files/20210412_161645_resized_968.jpg
cdlwingnut
PostPosted: Fri Apr 16, 2021 3:42 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
flipped the wing over an rib stitched the ribs with the braces blocking the path of the long needle. now the wing is ready for tapes.
 Filesize:  150.99 KB
 Viewed:  69 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 13 of 13
