weight and balance
Mark.Summers(at)lwbref.co
PostPosted: Wed Jan 18, 2006 6:04 am    Post subject: weight and balance Reply with quote
I have another question does anyone have page 1 and 2 of the of the
assembly weight and balance paperwork I have 3 and 4 which starts with step
2. I assume the instructions for leveling the aircraft for empty weights.
any help is appreciated Mark
rjdaugh(at)rapidnet.com
PostPosted: Wed Jan 18, 2006 9:33 am    Post subject: weight and balance Reply with quote
Mark,
What plane are you building?
Randy
PostPosted: Wed Jan 18, 2006 2:23 pm    Post subject: weight and balance Reply with quote
Its a KF 2. I am actually doing some fuselage splicing and will need to do
W&B as if I were building it. The splices are at the rear and will need to
re-weigh the plane . The sheets I have start with step #2 With the aircraft
and all fixed equipment installed, record the scale readings. I want to be
sure I don't mget the aft CG out of whack Thanks Mark
PostPosted: Thu Jan 19, 2006 3:46 pm    Post subject: weight and balance Reply with quote
Opps. I can't help with the KF 2.
Hopefully somebody here can.
Randy
Do not archive.
