1906
Posted: Fri Jul 02, 2021 11:49 am Post subject: Engine roughness at low power, 82% RPM? |
One of the M14Ps I fly seems to be rougher (not quite a popping sound but different than usual and has added vibration) close to landing. 82%, low throttle (very first notch on the Russian manifold pressure gauge or so). Both have MTV9 props which tend to prop brake during these conditions but the other engine is fairly smooth in comparison. It does have less than 200 hours on the engine whereas this one is about 620.
Any ideas?
Posted: Fri Jul 02, 2021 12:02 pm Post subject: Engine roughness at low power, 82% RPM? |
Check fir intake leaks. Especially if it has an intake drain kit. Also check all intake gland nuts.
Dennis
Any ideas?
http://forums.matronics.com/viewtopic.php?p=502686#502686
Posted: Fri Jul 02, 2021 12:10 pm Post subject: Engine roughness at low power, 82% RPM? |
Also check the condition of the manifold pressure hose and primer hose.
Dennis
Quote: | On Jul 2, 2021, at 4:04 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
> Any ideas?
1906
Posted: Fri Jul 02, 2021 12:11 pm Post subject: Re: Engine roughness at low power, 82% RPM? |
Thanks Dennis. I figured it might be an intake leak. Will do.
1906
Posted: Fri Jul 02, 2021 12:33 pm Post subject: Re: Engine roughness at low power, 82% RPM? |
One more thing - is there an easy way to determine which intake tube might be the culprit? Or might as well do the gaskets on all?
Posted: Fri Jul 02, 2021 2:17 pm Post subject: Engine roughness at low power, 82% RPM? |
The only way I know is to spray the suspected area with propane or carb cleaner with the engine running. But carb cleaner is flammable. Best to troubleshoot this when the engine is cold. So if you use carb cleaner be very careful. What you’re looking for is the engine RPM to increase if there is a leak wherever you spay.
Dennis
http://forums.matronics.com/viewtopic.php?p=502690#502690
markbitterlich(at)embarqm Guest
Posted: Fri Jul 02, 2021 4:03 pm Post subject: Engine roughness at low power, 82% RPM? |
How about Russian spark plug wires?
R/S
Mark
From: Anthony Savarese <dsavarese0812(at)bellsouth.net>
Date: 7/2/21 6:21 PM (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Re: Engine roughness at low power, 82% RPM?
--> Yak-List message posted by: Anthony Savarese <dsavarese0812(at)bellsouth.net>
Dennis
--> Yak-List message posted by: "1906" <zmadwolf(at)gmail.com>
_-============================================================
_-= - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Yak-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
GeorgeCoy
Posted: Fri Jul 02, 2021 5:48 pm Post subject: Engine roughness at low power, 82% RPM? |
You could use a propane torch but don’t lite the torch. Just use it like a sniffer and just wave the propane gas around the joints I will do the same thing with a lot less danger.
George Coy
Sent from my iPad
Quote: | On Jul 2, 2021, at 6:22 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
glipaz
Posted: Tue Jul 20, 2021 7:36 pm Post subject: Re: Engine roughness at low power, 82% RPM? |
Did you figure out what was causing your engine roughness?
1906
Posted: Mon Jul 26, 2021 9:22 am Post subject: Re: Engine roughness at low power, 82% RPM? |
Not yet. I am hoping to replace the intake gaskets/seals within the next 10 days.
stephen.hayne
Joined: 01 Nov 2013 Posts: 59 Location: United States
Posted: Wed Aug 04, 2021 12:33 pm Post subject: Re: Engine roughness at low power, 82% RPM? |
GeorgeCoy wrote: | You could use a propane torch but don’t lite the torch. Just use it like a sniffer and just wave the propane gas around the joints I will do the same thing with a lot less danger.
This is beyond cool, but with the cowling off and engine running (prop blast) do you have to run the "plumbers" torch at full bore to get a rise?
Just wondering...
_________________ -
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp |
