Procedure after extensive downtime?
PostPosted: Wed Oct 06, 2021 2:36 am    Post subject: Procedure after extensive downtime? Reply with quote
I have been doing some airframe work and the engine hasn't run for 3 months. All oil from the tank seems to have drained via intake drain and exhaust (will replace the oil pump eventually). Do I need to pre-oil the cylinders as prescribed in the Russian manual? Was thinking of treating it like an oil change and clean the screens too. Anything else?
