WAS: Sizing a B-lead ANL now "master fuse" on the batter
PostPosted: Wed Mar 02, 2022 10:54 am    Post subject: WAS: Sizing a B-lead ANL now "master fuse" on the batter Reply with quote
At 10:02 AM 3/1/2022, you wrote:
At 12:02 AM 3/1/2022, you wrote:
Sort of related query.
A J3 Cub is being converted to accommodate an 0-200 engine with electric start. Â
The battery box is behind the baggage compartment, and for the sake of simplicity, there is no master solenoid back there, so there is a hot #4 wire all the way top the firewall.Â
The only electrical load is the radio and intercom, for which there is a switch and circuit breaker.
I want to add a fuse of some kind at the battery box to prevent a "shower of sparks" welding event if there is an incident which causes the steel bits to cut into the hot battery cable.Â
What is the likely current draw on a typical lightweight starter for an 0-200, and what is the suggested "fuse " mechanism?
Does this airplane have an alterantor?
Are their any concerns for dealing with a
'stuck' starter contactor?
Have you crafted a power distribution
diagram that offers the total picture
of your proposed system?
What's the down-side of having a legacy
battery contactor at the battery location
with a switched fat-wire going to a starter
contactor on firewall and a fuse-block
to offer protected feeders to appliances?
The only circuit protection needed are
fuses in the fuse block and perhaps
a fusible link if you're going to carry
some engine driven power source.
What size/style battery is being
considered?
Dug around in the archives and found a sketch I
did for a fellow wanting to craft a battery-only
airplane with the option of adding an alternator
later. I've cleaned up that drawing and published
at:
http://aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z01A.pdf
Hope this is helpful.
out of that stuff?"
