Jabiru 3300 Engine for sale
broberts103
PostPosted: Thu Mar 03, 2022 6:58 am    Post subject: Jabiru 3300 Engine for sale Reply with quote
For sale:
2009 Jabiru 3300 S/N 33A2XXX
Purchased in 2015 from Pete Krotje (at) Jabiru usa.
Still in crate as shipped to me; never installed. Stored in climate controlled shop. I am unable to use due to Eyesight issues and reluctantly have to admit it is just taking up space.
Per the email I received from Pete back then:
The engine has the most recent cam, new con rod bearings, new pistons, rings and wrist pins, all new valves, new rocker bushings and new seals, gaskets and orings throughout. Cylinder barrels were honed. The engine has the upgraded longer throughbolts, the upgraded doweled flywheel attachment and the newer shorter pushrods and current fast bleed lifters. The engine had essentially a top overhaul plus a bit more.
Serious Inquiries only, please.
$7,500 plus freight to your USA 48 location.
Engine is located near San Antonio, TX if you want to personally inspect or pick up to save freight.
I also have the Zenith 601 XL Firewall Forward parts available as well. Email me if interested in either or both.
Bill
Broberts103(at)gvtc.com
Bill Roberts
Zodiac 601 XL
Wings Done, Working on Fuselage
