tomcostanza
Posted: Sat Apr 02, 2022 5:06 am Post subject: Spark suppression diode on starter MOTOR |
It's common (or maybe not so common) knowledge that spark suppression diodes are a good idea on relays and contactor coils. But I've found precious little discussion about putting one on the starter MOTOR (B lead). The motor windings have the same issue of collapsing magnetic fields. Is the battery supposed to absorb that energy? This is more of an academic question than a practical one, since airplanes aren't falling out of the sky without them.
Anyone?
_________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
Joined: 28 Mar 2008 Posts: 1908 Location: Riley TWP Michigan
Posted: Sat Apr 02, 2022 9:48 am Post subject: Re: Spark suppression diode on starter MOTOR |
Batteries don't absorb the energy from inductive voltage spikes.
The controlling switch contacts do. As the switch contacts open,
an arc jumps across the opening contacts. The energy is dissipated as heat.
Starter motors have counter EMF that might limit inductive voltage spikes.
_________________ Joe Gores |
Posted: Sun Apr 03, 2022 9:55 am Post subject: Spark suppression diode on starter MOTOR |
At 08:06 AM 4/2/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: "tomcostanza" <Tom.Costanza(at)gmail.com>
P.S. Heres an article I posted about 22 years
ago on the topic of spike suppression . . .
https://tinyurl.com/y79ht8zm
out of that stuff?"
tomcostanza
Posted: Mon Apr 04, 2022 3:44 am Post subject: Re: Spark suppression diode on starter MOTOR |
Thanks for that Bob. I read the article in its entirety. But I didn't see where it answered my question. To be clear...I understand why we put diodes across the coil of a contactor or relay. My question is, why don't we put diodes across the starter MOTOR? That has collapsing magnetic fields also doesn't it?
My conjecture tells me that:
The starter contactor has already disconnected the starter motor from everything. So no harm done if there is a flyback current. But I'm not an engineer, and would very much appreciate your educated explanation.
I did see one or two articles for Ford Mustang owners to add a diode here, but that's all. And it didn't explain why; just do it.
Thanks again Bob for all you have and continue to contribute to our knowledge of all things electronic.
Stay healthy everyone.
Tom Costanza
Ceengland
Posted: Mon Apr 04, 2022 5:52 am Post subject: Spark suppression diode on starter MOTOR |
On Mon, Apr 4, 2022 at 8:20 AM tomcostanza <Tom.Costanza(at)gmail.com (Tom.Costanza(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "tomcostanza" <Tom.Costanza(at)gmail.com (Tom.Costanza(at)gmail.com)>
Clear Skies,
Tom Costanza
| Hoping Bob won't mind if I take a swing at rearranging his answer...
Perhaps it's your starting point that's the problem. It isn't 'everything' that a flyback diode protects; it's the controlling switch's contacts that need protection from the arc that forms as they open.The suppression diode on the coil of the contactor protects the (relatively) weak pair of contacts in the switch that controls it, from the relay coil flyback current. With the starter (obviously a much larger, higher energy device than the relay coil), engineers designed its 'switch' (the starter relay) with *two* pairs of contacts, and a much stronger spring to open them than is seen in other relays. The combination of rapid opening due to the strong spring, and the division of load and arcing between the two pairs of contacts, and the overall extremely robust nature of the contacts, means that a flyback diode isn't needed to protect the relay contacts.
Viewed another way, if we used a robust enough switch to control the relay, with really fast acting contacts, we might be able to eliminate the flyback diode from the relay coil. But the diode is much cheaper/simpler than a switch that could handle the arc issue without damage.
_________________ Charlie |
tomcostanza
Posted: Mon Apr 04, 2022 6:50 am Post subject: Re: Spark suppression diode on starter MOTOR |
Thanks Charlie. So if I understand you correctly, there still is a flyback current from the motor, it just isn't an issue because the contacts on the starter contactor are more robust than a normal relay or battery contactor. Did I paraphrase your answer correctly?
Tom Costanza
Ceengland
Posted: Mon Apr 04, 2022 7:24 am Post subject: Spark suppression diode on starter MOTOR |
On 4/4/2022 9:50 AM, tomcostanza wrote:
Clear Skies,
Tom Costanza
Yes, that's a pretty good paraphrase of my paraphrase (which I *hope* is
a good paraphrase) of Bob's original explanation.
Posted: Mon Apr 04, 2022 8:51 am Post subject: Re: Spark suppression diode on starter MOTOR |
If it is desired to put a diode in parallel with the starter motor, the easiest way is to connect the banded
end to the downstream fat terminal of the starter contactor and the other end to ground.
It is really hard on a start contactor to chatter while attempting to crank the engine with a weak battery.
Ceengland
Posted: Mon Apr 04, 2022 12:35 pm Post subject: Spark suppression diode on starter MOTOR |
On 4/4/2022 2:31 PM, Robert L. Nuckolls, III wrote:
Quote: |
http://aeroelectric.com/Pictures/Cessna_Diode_Assy/
Are we not grateful NOT to own a TC aircraft?
Competent design is based on properties of materials,
management of energy and refinement of process.
But as we may observe in the photos cited above,
'refinement' hasn't really moved in the
right direction.
| EEYouch!
At those prices, a switch would be cheaper. (Unless it was a 'certified' switch...)
bob.verwey(at)gmail.com Guest
Posted: Tue Apr 05, 2022 12:12 am Post subject: Spark suppression diode on starter MOTOR |
..and one should consider duty cycle?
On Mon, 4 Apr 2022 at 23:29, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Charlie |
Dead on. The only thing I would expand upon
is the term 'damage'. 'Wear' is the operative
term. I recall a demonstration I did many moons
ago where I switched a 1.5 volt flashlight cell
across a 1 ohms resistor.
Approx 1+ amps of current flow. I did this with
a sub-miniature, 'micro' switch with the side
sanded off so that one might observe the inner
workings.
While watching the contacts under a microscope
in a dark room, I could see a tiny arc between
the spreading contacts. The color of the arc
was blue . . . HOT. This suggests that for
even the smallest energy levels, the potential
for erosion of metal off the contact surfaces
is not zero; hence wear is not zero either.
Engineering applications data for all switches
will include predicted SERVICE LIFE values
for switches under various operating conditions.
See:
http://aeroelectric.com/articles/Switch_Ratings.pdf
Diodes didn't even start to show up in TC aircraft
until the late 60's. I was at Cessna when we
started fabricating diode assemblies to facilitate
installation in various places about the systems
including contactor coils.
I remember Gordon Wood (PhD in physics)
bought an HP peak-reading voltmeter and discovered
that some contactor coil spikes exceeded 400-500
volts! The fact that such a potential existed
was contrary to our pledge of compliance with
Mil-STD-704 . . . so began a program to mitigate
our 'transgression'. It had nothing to do with
life of the battery contactor switch . . .
that astounding spike that just had to be dealt with.
Don't recall any discussions about ENERGY nor
how it might have propagated into the system . . .
but we sure stomped out those spikes. Here's
a constellation of Cessna diode assemblies
dating from the 1960's to present day.
right direction.
out of that stuff?"
Best Regards,Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
