Matronics Govrnor Mk 3 in UK Europa
Rowland_Carson
PostPosted: Mon May 23, 2022 3:11 pm    Post subject: Matronics Govrnor Mk 3 in UK Europa Reply with quote
I am currently prevented by an attack of sciatica from doing much physical work on my Europa build so have been trying to assemble all the paperwork and references I will need for LAA Engineering to clear my various mods.
I have fitted a Matronics Governor Mk 3 to the trim circuit so that I can have a stick-top trim switch in addition to the one on the panel. I can’t find any reference to this as a mod anywhere in the LAA documentation. I am sure I am not the only or first builder to incorporate this.
Has anyone else in the UK on this WhatsApp group fitted a Governor and what was the paperwork required? I’m hoping that its absence from the LAA mod listings mean that it might be a Trivial Change but I strongly suspect not!
Any relevant info welcome.
in friendship
Rowland
Davidcripps
PostPosted: Tue May 24, 2022 12:04 am    Post subject: Matronics Govrnor Mk 3 in UK Europa Reply with quote
I added a stick-top trim switch to both sticks many years ago, and a panel push-button switch to select between them. I didn’t have a Governor or anything like that.
I just added it to a list of minor electrical changes that I had made at the same time and submitted it as a minor mod to PFA (as it was then) with a simple, hand drawn sketch of the new wiring layout for the parts involved. Wasn’t a problem at all.
David
in friendship
Rowland
