Ignition..no power from Module A
BruceOviatt
PostPosted: Tue Aug 02, 2022 6:42 am    Post subject: Ignition..no power from Module A Reply with quote
Flew one hour after both mags on my 1994 912ul checked well.  After landing I rechecked the mags but the left one was dead. Then called a Rotax tech and checked ground connections and reversed connections from ignition bundle to both modules but no change so I replaced Module A as recommended.
 Started the engine with the right mag but still no spark from the left mag - Module A. Talked to a Rotax tech at Airventure.  Then did a continuity check of single wires coming from ignition bundle.  One red wire to Module A had no continuity so started trimming the  wire back until I had continuity.  Soldered a new wire to it and a new connecter to the other end. Plugged the Module A wire into the the new connector and now have good flow of power to those spark plugs.   Could have saved $800 if I had checked continuity first.
Credit goes to Morris Smith, Rotax Tech in Lucedale, MS.
Sent from Samsung tablet
