gerry.vandyk(at)eastlink. Guest
Posted: Sun Dec 31, 2023 8:05 am Post subject: Tailwind Electrical System Drawing and Power Analysis |
Hello again all
Well, with the most recent comments from Joe and Peter, here's what I
believe may become the final configuration.
I will stipulate, I recognize this is a whole lot more system than the
airplane needs to fly, however I believe it will be required to have the
'VFR Only" limitation removed from my flight limitations. And as
pointed out by a fellow Canadian in a DM, the panel has been built with
the "visual field" requirements in the Canadian regs. Specifically
backup nav instruments have to be within 12" of pilots centerline, and
there must be an independent direction instrument. I'll have a basic
whiskey compass up on the dashboard, though I might have gotten away
with the dual ADAHRS units.
As I was revising the drawing this morning I had one of those forehead
slap moments. I thought I was being clever using a dpdt relay to run
both the aux alt and the e-bus. In fact, if the OV relay tripped, it
would have taken both items down leaving me with a dark panel. Joe's
suggestion of locating the e-bus relay near the battery forced a
separate relay, which now means when the OV crowbar takes down the aux
alt relay, the e-bus will now remain powered by the battery.
I'll still welcome any additional comments pointing out deficiencies,
however I think we might just have this dialed in now.
I hope I can pay the help forward that I've received here. Thanks to
everyone.
Cheers
Gerry
 Download |
| Filename: |
C-GVDZ_Electrical_System_Power_Distribution_C.pdf |
214.63 KB |
| Downloaded: |
374 Time(s) |
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Sun Dec 31, 2023 9:58 am Post subject: Tailwind Electrical System Drawing and Power Analysis |
Thanks again Joe. I had already marked up the backup OV breaker to 5
amps, but you're quite right, on the much smaller alternator 1 or 2 amps
would be about right. It's a 5A breaker on the 60 amp alt.
On the E-bus relay, another of those 'facepalm' moments. I'm showing my
mechanical engineering side, and not thinking through electrical flow
properly. Gotta get better at that. ;^)
I had the thought of connecting the E-bus relay with the fuseable link,
but hadn't drawn it that way. the battery, b-bus and contactor are all
screwed down to one plate behind the seats, I'll bolt the relay there as
well. I'll set up a loop of fuselink to connect the relay, and we
should be good.
Thanks again, you're help is absolutely invaluable.
Gerry
