draftsjust417(at)gmail.co Guest
Posted: Thu Apr 18, 2024 8:21 am Post subject: CJ6A tach generator, cleaning? |
Good morning all-Anyone have advice on cleaning and/or maintenance on the CJ6's small tach generator (ref p/n GZ-14) for the Housai engine?
Ref mounted on LH side, below the left magneto.
I'm getting either zero or wildly erratic indications on BOTH front & rear tachometers; thoroughly cleaning the tach gen's cannon plug didn't help this time.
The clever tach system is simple and self-contained, and I'm thinking I may have a problem internal to the tach generator itself?
I installed it new ~6 yrs ago.
Thoughts, experiences??
My engine is running great.
Thanks---Â
Justin Drafts
Everett, WA
markbitterlich(at)embarqm Guest
Posted: Thu Apr 18, 2024 9:32 am Post subject: CJ6A tach generator, cleaning? |
I've had problem with cold solder joints in the plug connecting to the tach gen itself. I'd suggest labeling and removing the wires, possibly cutting back about an inch and restripping, retinning, and soldering back into place the three wires.
Alternatively you can remove the tach gen, and then spin it with an electric drill while watching the voltage (AC) one phase at a time or between two phases at a time (easier). If you see readings jumping around, the gen is bad.
Mark
-------- Original message --------
Date: 4/18/24 12:25 PM (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Yak-List: Re: CJ6A tach generator, cleaning?
Thanks---
Justin Drafts
Everett, WA
Clouddog
Posted: Thu Apr 18, 2024 4:47 pm Post subject: CJ6A tach generator, cleaning? |
Justin,Â
Not only did I clean the cannon plug, I took mine apart and reset the wires. For me in the beginning,it was a dirty/loose cannon plug. Issue came back and when I reset the wires, I cleared my issue.Â
Greg
On Thu, Apr 18, 2024, 12:26 Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Quote: | Good morning all-Anyone have advice on cleaning and/or maintenance on the CJ6's small tach generator (ref p/n GZ-14) for the Housai engine?
Thanks---Â
Justin Drafts
Everett, WA
