stalls & spins
graham(at)gflight.f9.co.u
PostPosted: Tue Aug 01, 2006 3:02 pm    Post subject: stalls & spins Reply with quote
Hi All
I was greatly saddend to hear about Cliff Shaw's accident. His happened
near the ground on approach; as most of you know I have some experience
of Europa stall/spin, mine happened just after take off. In both cases
spin recovery is impossible this close to the ground, indeed partial
recovery may make things worse. You hit the ground harder.
Pete Clarke tested the spins of the original Classic prototype, G-YURO
extensively. One notable feature he found was that even after a twelve
turn spin he could let go of the controls and the aeroplane would
recover in less than two turns.
There are many GA types that are designed to be almost spin proof, this
is a mixed blessing because if it's hard to spin it will be just as hard
to stop the spin when it occurs. The Yankee was notorious and there were
several fatal accidents until intentional spinning during training was
forbidden. Remember also that very few certified or homebuilt GA types
had anything like the testing the Europa had. I remember Richard Trikle
asking Pete Clarke if he'd test the Kiss. No American pilot was prepared
to do it.
There are quite a few Classics that have a nasty wing drop flaps down.
G-KWIP was one. We had removed the stall strips because we felt we
needed the extra take off performance for farm strip flying. Ours was
around 450 meters at the time. The trouble with the Classic wing is that
it is not easy to finish the leading edge without degrading the very
subtle leading edge shape, which has a slight bump underneath and a
fairly sharp nose radius. Eventually, after much arm twisting, I got
hold of the coordinates of the airfoil and made some templates for the
leading edge. These were used on several Classics, Charlie Laverty's,
Tony Higgins' and Colin Smallwood's, I haven't heard from Tony re flying
qualities but the other two have excellent stall characteristics and so
does Trevor Jackson's, (kit no. 4!)
This illustrates the variability that Mike Parkin mentions.
Ivan did a lot of tuft testing trying to master the stalling
characterisitics and found that as long as the stall starts at the
leading edge it will be relatively progressive. However, sometimes the
stall starts at the trailing edge and then the whole upper surface
"unzips" and will cause a sharp wing drop. The stall strips help to make
the stall start at the front and at the wing root. The sharp LE radius
has a similar effect and I'm sure this is why some Classics are
unpredictable ( too large LE radius) whereas most XSs, which have a jig
moulded LE are relatively benign. (Not that I've flown many btw, so get
a second opinion!) The XS also has more washout which helps keep the
stall away from the tips.
Mike will have a much more valid opinion than me but I believe the
sensible way to monitor airspeed is by angle of attack, the instrument
tells that that your airspeed is going to change, you can correct the
changed AoA instantly and speed won't change The ASI tells you at least
20 seconds after it's changed which means you then have to regain
momentum which will take another 20 seconds or more. Another advantage
that correct AoA is not dependant on weight, so the figure for stall,
cruise max range etc all remain constant.
my 2 cents
Graham
From: "Mike Parkin" <mikenjulie.parkin(at)btopenworld.com>
Subject: Re Wing Drop in the Stall
Jos,
I think that the original foam built wings are likely to vary slightly
more
in performance than the factory made wings purely because of the nature
of
construction. Profiling the wing is a laborious process and the end
result
is very much an 'eyeball dependent' operation. I think it would be fair
to
say that the jig made factory wings are likely to produce a more
consistent
result.
The very nature of the
wing
seems to provide a useable amount of lift until the stall, at which
point
the loss of lift from the wing seems to be almost total. Now if one
wing
stalls before the other it is conceivable that the aircraft might roll
on
its back.
Mark Burton
PostPosted: Wed Aug 02, 2006 1:13 am    Post subject: Re: stalls & spins Reply with quote
Folks,
my 2 cents
Graham
There is much good information in Graham's message but I feel that this last paragraph is misleading. Unless your ASI is particularly sluggish, it will indicate changes in airspeed almost instantly (i.e. not 20 seconds later). What takes the time is actually changing the speed of the aircraft relative to the surrounding air. Fitting an AoA gauge does not make your aircraft accelerate any quicker!
Let's imagine the situation where you are on approach and your airspeed is a little below the optimum speed (the AoA is higher than desired). Assuming you are not too low, you lower the nose to increase the speed (and reduce the AoA). As soon as the nose is lowered, the AoA will decrease and if you have an AoA gauge that will be indicated immediately. The airspeed, however, does not change straightaway (the ASI lag!!!) After a while, your airspeed will settle at the new increased value. (perhaps a kind aerodynamics person can provide us with a succinct description of what causes the airspeed to increase when the AoA is reduced).
Moving the stick forward to reduce the AoA is the crucial action. Having moved the stick, the pilot then has to wait until the speed stabilises before sampling the ASI again (all gliding instructors will remember giving this demo). If the speed doesn't have to change by very much (say, < 5 kts) then the pilot doesn't have to wait very long (certainly less than 20S).
The rational behind the talking ASI is that if the airspeed on approach is not far from the desired speed, then the pitch/throttle adjustments required to return to that speed are small and the time lag between making an adjustment and achieving the desired speed is small. The pilot is "nagged" into maintaining the correct airspeed through small changes in pitch/power.
By nagging the pilot to maintain a sensible speed, the talking ASI not only protects against stalling, it helps you obtain the stabilised approach that Mike Parkin enthused about and is so important when operating out of small fields.
I understand the benefits of flying by AoA and if someone produced a low cost, reliable, easy to fit and calibrate, AoA instrument that didn't require you to have your eyes in the cockpit on approach, I would be tempted to have one.
Mark
asarangan(at)YAHOO.COM
PostPosted: Wed Aug 02, 2006 6:15 am    Post subject: stalls & spins Reply with quote
I don't see the ASI and the AOA as entirely different things, especialy
in a small GA cockpit. The ASI can be calibrated to read angles instead
of speed based on aircraft weight, like the movable outer ring that is
used for calibrating TAS based on temperature. A true AOA independent
of weight is useful only in large transport aircraft where the weight
could vary significantly.
--- Mark Burton <markb(at)ordern.com> wrote:
Folks,
instrument
the
least
advantage
stall,
> my 2 cents
> Graham
Mark
http://forums.matronics.com/viewtopic.php?p=51717#51717
Dave Miller
PostPosted: Wed Aug 02, 2006 7:27 am    Post subject: Stalls & spins Reply with quote
One useful thing about learning to fly in giders, was the constant yelling from the back seat;
Keep the speed up
Keep the string straight.
I still miss the yaw string, the cheapest and most useful instrument made.
I'm indebted to Carl for his comments on the ball. In what feels like straight and level flight, mine sits a bit to the left.
My feeling was that the instrument was wrong, or that the view from the left seat was distorting my perspective, or that I'd just lost the touch for what is straight and level.
Also to Mike for comments regarding the ailerons, mine are level on the ground, but seem to adopt a slight droop in cruise.
Some things to look at and fix on C-FBZI
Dave A061
BEBERRY(at)aol.com
PostPosted: Wed Aug 02, 2006 7:58 am    Post subject: stalls & spins Reply with quote
The usual cause of stall on the approach - or anywhere I suppose, is the0 application of up elevator when pilot perception is that of being too low.
The correct action should surely be emphasised again and again - elevator0 for change of speed and throttle for height.
Patrick
willie.harrison(at)tinyon
PostPosted: Wed Aug 02, 2006 8:33 am    Post subject: stalls & spins Reply with quote
Surely it depends on how much G you are pulling (or not)??
Willie Harrison
G-BZNY
-- Original Message --
Date: Wed, 2 Aug 2006 07:13:54 -0700 (PDT)
Subject: Re: Re: stalls & spins
Reply-To: europa-list(at)matronics.com
> Folks,
> instrument
> the
> least
> advantage
> stall,
> > my 2 cents
> > Graham
> Mark
___________________________________________________________
Tiscali Broadband from 14.99 with free setup!
http://www.tiscali.co.uk/products/broadband/
paddyclarke(at)lineone.ne
PostPosted: Wed Aug 02, 2006 10:01 am    Post subject: stalls & spins Reply with quote
Hi All,
I have to that I'm with Graham here. Not only does the AoA system
solve the problem of the increased stall speed with bank, it also
indicates instantly if an accelerated pitch input is made - not so
the ASI.
I have the Proprietary Systems AoA. I was recently asked to
demonstrate it to another Europa builder. Having investigated the low
speed handling solo, and with approx half fuel, the day before, I was
surprised by how much faster the IAS was for the same AoAs, with 2 up
and near full fuel.
The system is relatively easy to fit if it is put in as original
equipment and, to answer Marks point, has a good aural warning. Just
remember to ignore the American lady when she says 'Angle, Angle,
PUSH !' and you're in the flare !!
Cheers, Paddy
Paddy Clarke
Europa XS - 404 G-KIMM
Mark Burton
PostPosted: Wed Aug 02, 2006 11:18 am    Post subject: Re: stalls & spins Reply with quote
paddyclarke(at)lineone.ne wrote:
Hi All,
Yes, but it still requires you to look inside the cockpit while flying the approach to see the AoA display. Once you get to the point of flaring you don't need any instruments at all.
carl(at)flyers.freeserve.
PostPosted: Wed Aug 02, 2006 2:29 pm    Post subject: stalls & spins Reply with quote
I would suggest that the ASI should only be part of the equation. You need
to know the correct attitude (with reference to the horizon) that gives a
safe approach speed. If you fly with reference to the ASI alone you end up
chasing the airspeed and worse still have your eyeball inside the cockpit
instead of keeping an eye on the attitude and where you are heading.
On my first ever solo (in a glider) the ASI failed completely and I had to
fly the circuit and land without any speed reference whatsoever. Fortunately
I was taught to fly by attitude and coped with what would have otherwise
been a nasty situation.
If your airspeed indicator were to fail would you know what attitude to fly
to land safely. If you dont recognise what attitude gives a safe flying
speed (flaps up and flaps down) would you be able to cope with such an
emergency.
Trevpond(at)aol.com
PostPosted: Wed Aug 02, 2006 2:33 pm    Post subject: stalls & spins Reply with quote
The correct action Patrick is to fly the aircraft to the published0 numbers!
Trev Pond
Kit 598
PostPosted: Wed Aug 02, 2006 7:45 pm    Post subject: stalls & spins Reply with quote
I agree entirely. In fact I teach my primary students how to approach
and land with all instruments covered, including airspeed and
altimeter. If you know the pitch + power combination for every flight
configuration, you don't need much else. However, the pitch+power
combination depends on aircraft weight and load factor. If you use
AOA+power, it would be independent of weight and load factor. This is
why some people prefer AOA. My point was that rarely do we have large
variations in load factor or weight to make this a highly useful
instrument. I would be interested to know if there are any studies that
show than an AOA makes that much difference in stall-spin accidents. In
my observation flying with many pilots, new and old, by the time
someone gets into a dangerously slow airspeed and a screwed up
approach, they are rarely able to pay attention to the flight
instruments or even hear the stall horn. What saves them is their basic
airmanship to recognize the unusual attitude and recover it to a
familiar pitch + power configuration. I doubt that yet another
instrument on the panel is going to be of much help to those who get
that far into the danger zone.
need
gives a
end up
cockpit
had to
Fortunately
otherwise
to fly
flying
an
emergency.
Andrew Sarangan
http://www.sarangan.org
PostPosted: Thu Aug 03, 2006 1:37 am    Post subject: stalls & spins Reply with quote
Hi Mark,
I'm sure we can agree that no instruments are needed in the flare -
my attempt at a bit of levity obviously didn't come through!
I am a great fan of your talking ASI, it's a valuable contribution to
flight safety and I would certainly have fitted one if I didn't have
an AoA indicator. It is also much easier to retrofit, though it does
depend on the validity of the target airspeed. To look at the
indications of an AoA you have, of course, to glance inside - though
mine is fitted at the very top of the instrument panel, so I might
just pick up the bright lights in my peripheral vision.
However, one day you may be making a rather tight turn onto final,
roll on a bit of extra bank to stop the tailwind blowing you through
the C/L, then pull rather sharply back as you realise you've let the
nose drop - just as you hit the turbulence from the top of the big
hangar. An American lady giving you a harsh rebuke may just save your
life, whereas the English lady would be quietly content. After all,
your airspeed is exactly the number she's been told to expect.
All the Best, Paddy
Paddy Clarke
Mark Burton
PostPosted: Thu Aug 03, 2006 2:10 am    Post subject: Re: stalls & spins Reply with quote
Hi Mark,
All the Best, Paddy
Hi Paddy,
I agree with everything you say here except the bit about the turbulence because if the wind speed (relative to the aircraft) changes rapidly, the talking ASI will pick that up as quickly as the AoA instrument does. As you point out, the real benefit that AoA gives over airspeed is the detection of the
accelerated stall. It did occur to me during development of the talking ASI that by adding an accelerometer the widget could take into account the higher loading. Perhaps I should investigate that idea further.
I've said enough now, everyone must be bored to tears.
If anyone wants to discuss the talking ASI further, please send email to enquires(at)smartavionics.com
Mark
Mark Burton
PostPosted: Sat Mar 17, 2007 2:25 pm    Post subject: Re: stalls & spins Reply with quote
Folks,
Thinking back to the conversation last year on stall+spins and the recent article in GASCO Flight Safety about cheese (you have to read the article to understand).
Some of you may be interested to know that I am now producing Mk2 SmartASS units that not only provide the features of the MK1 units (talking ASI, and audible speed director) but it also features an accelerometer that measures the G you are pulling and factors that into the speed director calculation. It works very well as an aid to preserving the "stall speed margin" as well as making flying a stabilised approach ridiculously easy.
I must stress that the SmartASS is not a stall warning device.
The Mk2 units also feature audible undercarriage and general alerts.
As ever, technical blurb, prices, etc. can be found at www.smartavionics.com
Mark
