Drill hole in Flap Motor
LarryRosen
PostPosted: Wed Jan 18, 2006 12:51 pm    Post subject: Drill hole in Flap Motor Reply with quote
A 1/16" hole needs to be drilled through the upper lip of the flap motor
to accept safety wire. Any hints or tips on the best way to do this?
Larry Rosen
#40356
<http://lrosen.nerv10.com>
Larry Rosen
#40356
N205EN (reserved)
<http>
Randy(at)abros.com
PostPosted: Wed Jan 18, 2006 4:13 pm    Post subject: Drill hole in Flap Motor Reply with quote
Easy to do. Start strait in until you can angle the drill with out it
slipping. Drill in about 1/2 way. Then stop and come in from the other
side. Randy
LarryRosen
PostPosted: Wed Jan 18, 2006 4:40 pm    Post subject: Drill hole in Flap Motor Reply with quote
Thanks Randy.
I was hung up trying to make it straight, but that is not required since
it is for the safety wire.
Larry
side. Randy
Larry Rosen
#40356
N205EN (reserved)
<http>
ricksked(at)earthlink.net
PostPosted: Wed Jan 18, 2006 11:00 pm    Post subject: Drill hole in Flap Motor Reply with quote
Larry,
I have not drilled mine but I have done a lot of these safety wire holes before. File a small flat where you want the hole to start, center punch the starting point and drill in vertically just enough to be able to get the drill to start and hold at a 45 degree angle then finish the hole. I have found that using the short threaded drill bits work the best because they don't break as easily. Go slow and let the bit do all the work, if you push even a little it will snap right off.
Rick S.
40185
Fuselage
