tip up
dhall(at)donka.net
PostPosted: Wed Aug 02, 2006 8:19 pm    Post subject: tip up Reply with quote
I'm building a tip-up, so0 for me this is not a debate about that option.
I just have a question0 for the tip up crowd with experience in IMC...
Does it leak when you're0 flying through occasional weather? Any pointers from folks who have faced0 or addressed this problem?
I would like low0 odds that my planned glass panel goes zzzzzt should I end up in some showery0 conditions...
Don0 Hall   0
N517DG (registered)
rv7 fuselage
http://rv7.donka.net
dan(at)rvproject.com
PostPosted: Wed Aug 02, 2006 9:01 pm    Post subject: tip up Reply with quote
Mine doesn't leak in flight. It leaks a bit through the front0 gap when sitting out in the rain uncovered. So I cover it.
)_( Dan
RV-7 N714D (1021 hours)
http://www.rvproject.com
Travelair
PostPosted: Wed Aug 02, 2006 9:24 pm    Post subject: tip up Reply with quote
Dear Don;
We have just0 picked up our new RV7a(w/tiltup) from Florida and
did infact get into some rain coming home to the west0 coast, and yes
our feet did get wet. Once home and in the hangar, I0 found that there was
no rubber insulation in the tilt up hinge area, thus I0 believe that we have
found our problem ?
    0 Don
sa300(at)uniserve.com
PostPosted: Thu Aug 03, 2006 5:28 am    Post subject: tip up Reply with quote
Mine doesn't leak in flight or on the ground. The water will enter if you open it in the rain. So to prevent the water from getting into the avionics I made a small eves trough to catch the run off and drain it to the side of the aircraft.
Dan Checkoway wrote:
Mine doesn't leak in flight. It leaks a bit through the front gap when sitting out in the rain uncovered. So I cover it.
)_( Dan
----- Original Message -----
To: rv7-list(at)matronics.com (rv7-list(at)matronics.com)
Sent: Wednesday, August 02, 2006 9:17 PM
Subject: tip up
I'm building a tip-up, so for me this is not a debate about that option.
I just have a question for the tip up crowd with experience in IMC...
Does it leak when you're flying through occasional weather? Any pointers from folks who have faced or addressed this problem?
I would like low odds that my planned glass panel goes zzzzzt should I end up in some showery conditions...
Don Hall
N517DG (registered)
rv7 fuselage
say.ahh1(at)verizon.net
PostPosted: Thu Aug 03, 2006 5:52 pm    Post subject: tip up Reply with quote
After seeing many past threads on this problem and noting some builders
at Osh who taped the front seam while their planes sat outside, has
anyone done a redesign where the canopy does not use a pin hinge and
expose the interior? For example, Lancair has the fuse sealed, with the
canopy frame laying on this, and tilting up via two C arms in the comb
similar to many car trunk designs. Thoughts?
Carl Peters
RV-9A empennage, debating tip-up vs. slider
dhall(at)donka.net
PostPosted: Thu Aug 03, 2006 7:45 pm    Post subject: tip up Reply with quote
For the curious, I heard0 a story about a tip-up guy whose radio went out passing through some0 rain. He supposedly poured the water out of the radio after the0 flight.
>:O
You can bet I'll be0 trying to think like a clever water drop when I get to finishing. 0 Smile
If you solve your problem, do tell. 0 Thanks!
Don0 Hall   0
N517DG (registered)
rv7 fuselage
From: owner-rv7-list-server(at)matronics.com0 [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of0 travelair
Sent: Thursday, August 03, 2006 1:18 AM
To:0 rv7-list(at)matronics.com
Subject: Re: tip0 up
Dear Don;
found our problem ?
    0 Don
scott(at)randolphs.net
PostPosted: Thu Aug 03, 2006 8:37 pm    Post subject: tip up Reply with quote
My tip up did leak in flight, and did cost me a radio repair as a result. I
spent a bit of time working on it and it's been dry for a year now, though
it's probably only a matter of time before it leaks again.
There are several areas of concern:
The front edge of the canopy needs a good rubber seal that fills the whole
gap tightly. This can be tricky to accomplish, especially at the lower
front corners which have to "slide" over the side of the fuselage. This is
a less critcal area, though, as it's not likely water will get from there to
something expensive. When I finally got my installed correctly and tightly
enough to avoid leakage I then had to deal with whistles from air flow
sneaking past, though I eventually whittled them away by gluing in little
bits of foam here and there to fill gaps and damp vibrations in the seal.
The bigger problem is the hinges. I've not looked at the details on the -7
but I _think_ they're very similar to what's on my -6 and it's really tricky
to get it sealed up over the top of the hinges as they extend so close to
the forward skin and need to come up and forward as the canopy opens. If
you're careful triming the skin in this area to leave yourself enough
backing for the seal you'll probably be okay. I had to rely on stuffing it
full of profressional grade caulk and then carving out enough room for the
hinge to travel. Ugly but it did finally work.
The third thing to watch out for are rivets and seams where the skin
attached to the bulkhead and makes the seat for the front of the canopy. In
my plane there are a few small holes where the bulkhead was notched to
folder over in the curve and aren't _quite_ covered by the forward skin.
These have also been filled with caulk. (thankfully they're not visible
with the canopy down)
Finally, I have some pop rivets in my canopy assembly that needed to be
filled with caulk where the stem "popped" out and left a hole in the middle
of the rivet.
I've definitly heard folks compaining about leaks in their sliders too. For
what little it's worth, though, if I had it to do again, I think I'd go
slider and sacrafice the uninterrupted view (which IS spectacular) so that
if water got in it landed on my head and upolstry instead of my panel.
There is also the issue of rain on the ramp and getting wet behind the panel
just getting into the aircraft (which also happened to me).
I've not done it yet, but some kind of removable "splash shield" over the
top of the avionics to protect them has been lurking in the back of my mind
for a while.
Scott
RV6a
550 hours
dhall(at)donka.net
PostPosted: Mon Aug 14, 2006 2:41 pm    Post subject: tip up Reply with quote
This thread was very helpful. Thanks to all.
Only thing missing is pics showing some of the things mentioned.
If you have them, can you forward links or attachments?
Thanks!
Don Hall
N517DG (registered)
rv7 fuselage
