RV4 - FLOWSCAN and ELECTRIC FUEL PUMP
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
RV4WGH(at)aol.com
PostPosted: Sat Aug 26, 2006 7:25 pm    Post subject: RV4 - FLOWSCAN and ELECTRIC FUEL PUMP Reply with quote
I am trying to figure out where to locate the fuel Flowscan 201B and the electric fuel pump. I have read various comments about how much straight line should be before and after the flow scan unit (6 inches) and I'm having trouble finding a location to accommodate that. Also, I talked to a fellow RV builder to day who said he learned at OSHKOSH this year that the Flowscan should be located prior to the electric fuel pump.
What have others done?
Wally Hunt
Rockford, IL
RV-4 Finishing Kit
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
smokyray(at)yahoo.com
PostPosted: Sun Aug 27, 2006 7:34 pm    Post subject: RV4 - FLOWSCAN and ELECTRIC FUEL PUMP Reply with quote
Sorry Wally, I use an EI FP-5 and the flow sensor is between the carb and outlet line of the engine driven pump. My Facet pump is located in the center console on the outletb line from the selector valve per the pre- 89' builders manual..
Rob Ray
RV4WGH(at)aol.com wrote:
[quote] I am trying to figure out where to locate the fuel Flowscan 201B and the electric fuel pump. I have read various comments about how much straight line should be before and after the flow scan unit (6 inches) and I'm having trouble finding a location to accommodate that. Also, I talked to a fellow RV builder to day who said he learned at OSHKOSH this year that the Flowscan should be located prior to the electric fuel [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
