701 Nosegear Bungee
mcsheas(at)earthlink.net
PostPosted: Sat Jan 21, 2006 12:05 pm    Post subject: 701 Nosegear Bungee Reply with quote
I have recently purchased a 701 (completed in 1992) and am in the process of
installing the updated firewall. I ordered all parts from ZAC and spoke
with Nick/Roger several times throughout the project. Once I completed the
engine (ROTAX 582) re-install I found that the bungee did not have any give
AT ALL. This is true even with my additional 200 pounds pulling down on the
mount. After doing an archive search I found several messages from people
with the same experiences but was not able to find any messages concerning
successful remedies. I contacted Nick at ZAC and he did not seem familiar
with or have a good answer to the problem. Has anyone else run into this
and how have you solved the problem.
Zenith sent the 5/8, 8 inch bungee (ACS# 1080) rated at 750lbs. I confirmed
that it was not the 1080HD rated at 900 lbs. The Spruce catalog does not
offer an 8 inch bungee with less load rating. I contact SBC Industries (the
spring cord manufacturer that Spruce uses) and they offer lighter weight 8
inch bungees but have a 5 bungee minimum order. I'm considering going down
that road but would like to know if there is an easier fix for this.
Steve McShea
Clovis, CA
N701JC
cfd(at)thegateway.net
PostPosted: Sat Jan 21, 2006 1:49 pm    Post subject: 701 Nosegear Bungee Reply with quote
I have a 701 with a Jabiru 2200 on which is about the same weight as the
Rotax 582. I also have the lighter nose gear bungee. I have almost 200
landings and I still cannot depress the bungee standing still. But when I
taxi over rough ground it does flex and works OK. I would try it like it is
and see how it does. I have the tundra tires and keep about 10 # in the
mains and 8 # in the nose, really smoothes out my rough runway.
Chuck D.
N701TX
ronflys701
PostPosted: Sun Jan 22, 2006 3:51 am    Post subject: 701 Nosegear Bungee Reply with quote
They are tough and don t move much but after a few landings they do get
better? I thought the same thing
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: 701 Nosegear Bungee
Date: Sat, 21 Jan 2006 12:03:35 -0800
of
the
confirmed
(the
Steve McShea
Clovis, CA
N701JC
MSN Calendar keeps you organized and takes the effort out of scheduling
get-togethers.
first two months FREE*.
