jablackwell(at)ev1.net Guest
Posted: Thu Jan 19, 2006 6:01 pm Post subject: Rotax 912 Carb Venting |
This has probably been addressed on the list before, so hope the
old timers will forgive me. It occured to me that the vent tube
on the bing carbs present a fire hazard. Should the float stick
on either carb, then gasoline would be flowing out of the vent
tube and on the Kitfox would likely come in contact with the
exhaust pipes and muffler. I would not want to be in my Kitfox if
this happened.
Has there been any instances of a fire because of sticking
floats? More importantly, does anyone know of a solution? Not
flying is not an option.
Jimmie
Sent via the EV1 webmail system at mail.ev1.net
rjdaugh(at)rapidnet.com Guest
Posted: Thu Jan 19, 2006 6:47 pm Post subject: Rotax 912 Carb Venting |
Jimmie,
Do you have trays under your carbs? I was provided two little catch trays
that fit close up under the carbs and are fitted with hose fittings to carry
overflow down and out the cowl. They are kind of a nuisance at times, but
should do the job.
Randy = Series 5/7 - 912S
fordm2003(at)yahoo.com Guest
Posted: Thu Jan 19, 2006 8:12 pm Post subject: Rotax 912 Carb Venting |
Hi Jimmie,
If you don't have trays and you want to re-route the vent lines so the a fuel overflow won't spill onto something hot, you can. However, these lines are sensative to pressure changes, so you won't want to extend the lines too much.
I think the biggest mistake some poeple have made is to extend the vent lines so that they reach the outside of the cowl.
from: http://www.ultralightnews.com/enginetroublshooting/rotaxtr/trrtx1.htm
"There are two vent tubes located on the side of the Bing carb. Do not connect any additional hoses to these vents, or vent them outside an enclosed engine installation. By venting outside the engine cowling you create two different air pressure areas, that of the outside air, and that of the air inside the engine cowling, which can effect you fuel mixture."
Mike
this happened.
Jimmie
Photo Books. You design it and well bind it!
jdisher(at)intergate.com Guest
Posted: Fri Jan 20, 2006 8:41 am Post subject: Rotax 912 Carb Venting |
Whatever you do, don't tamper with the vent tubes. I increased the
length on my
left one and the engine dropped two left cylinders on take-off twice
during the
next 8 times I flew the plane. Really gets your attention. The easiest and
safest solution is to take a small funnel with a longer hose attached, fasten
it up under the carb, and merely lay the vent tube in it, so that if
fuel drips
out it will be collected by the funnel and drained away from the hot
exhaust and
you have not upset the balance of the carb.
this happened.
Jimmie
aerocontrols(at)clearwave Guest
Posted: Fri Jan 20, 2006 10:33 am Post subject: Rotax 912 Carb Venting |
Jimmy,
There are drip trays available that fit under the carbs.. I know of no
fires resulting from overflowing carburetors.
One thing you do not want to do is extend the vent lines and move them away
from the carburetors. This changes the pressure in the float bowls
resulting is mixture changes...
regards
Bob Robertson
Light Engine Services Ltd.
Rotax Service Center
Aero Control Enterprises, Inc.
St. Albert, Ab. T8N 1M8
Ph: (Tech Support) 1-780-418-4164
Ph: (Order Line) 1-866-418-4164 (TOLL FREE)
www.rtx-av-engines.ca
www.aerocontrols.net
rwill1(at)adelphia.net Guest
Posted: Fri Jan 20, 2006 2:02 pm Post subject: Rotax 912 Carb Venting |
Bob,
Is there a "recommended" length for the vent tubes to extend?
Posted: Fri Jan 20, 2006 3:36 pm Post subject: Rotax 912 Carb Venting |
No trays with mine. Trays sound like the answer to my concerns.
Anyone know where to get them?
Jimmie
Posted: Fri Jan 20, 2006 4:07 pm Post subject: Rotax 912 Carb Venting |
Jimmy,
I will ceheck to see what is hanging around is the used parts dept. Will
e-mail you Monday. Maybe someone has some they could part with.
regards
Bob Robertson
pwmac(at)sisna.com Guest
Posted: Fri Jan 20, 2006 5:20 pm Post subject: Rotax 912 Carb Venting |
Trays come with the 914 and can be purchased seperately
A Rotax guy told me to leave the plastic tube where it was from the factory
and put a Tee on its end then run a longer tube to the cowl bottom. Didn't
do it, but it is an interesting thought.
Paul
Jimmie
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 20, 2006 6:08 pm Post subject: Rotax 912 Carb Venting |
California Power Systems has them:
http://www.800-airwolf.com/
Click on online store, then click on search. You are looking for carb pans
Lowell
Posted: Sat Jan 21, 2006 8:45 am Post subject: Rotax 912 Carb Venting |
Rick,
The lines as they are shipped from the factory are 120mm (a tad longer than
4 3/4").
Thats what I'd stay with. Differences in cowling pressures and temperatures
between airplanes
could make a difference in air pressure in the float bowl. Therefore any
changes to where the float bowl chambers tubes are placed could result in a
dramatic change.
Hope this helps
Bob R
Posted: Sun Jan 22, 2006 5:42 pm Post subject: Rotax 912 Carb Venting |
Just a note to say thanks for all the input on 912 carb venting.
You all sure gave me a lot to think about.
Currently, I am in the process of changing my engine mount shock
pads. This is one heck of a chore. Anyone contemplating doing
this may want to contact me and perhaps I can save you some
pain. So far, I have removed the exhaust system and most of the
coolant lines. I was surprised to find that even after 11 years
and 340 engine hours the pads are in good condition. They look
bad on the surface, but when I took them out of the mounts they
are ok except a very thin layer of deteriation on the surface. I
am changing them anyway since I have them apart.
Anyone know how long these things can last?
Jimmie
KITFOXPILOT(at)msn.com Guest
Posted: Sun Jan 22, 2006 6:21 pm Post subject: Rotax 912 Carb Venting |
DON'T KNOW OW LONG THEY LAST, BUT I ALSO CHANGED MINE, WHAT A JOB.
Ray
cliffh(at)outdrs.net Guest
Posted: Sun Jan 22, 2006 7:02 pm Post subject: Rotax 912 Carb Venting |
If I remember correctly, Skystar recomminded that they be changed annually.
Floran H.
