Leading Edge/Tank Attach Strips - Question
sshook(at)cox.net
PostPosted: Sat Sep 09, 2006 12:15 pm    Post subject: Leading Edge/Tank Attach Strips - Question Reply with quote
Hey all,
I am looking for some help locating the leading edge/tank attach strips. According to my instructions I am supposed to be looking for W-423 Attach Joint Plate but I do not even see that in my parts manifest. The only thing that references tank and join are 2 strips of AS3-032X 1 1/2 X 36 1/2 Tank Joint Plate.
Are these strips what I am looking for?
Thanks for the help
Scott & Jenni
RV-7A N696JS
Left Wing drilled - ready to start on tanks (ugh!) [quote][b]
davcor(at)comcast.net
PostPosted: Sat Sep 09, 2006 2:13 pm    Post subject: Leading Edge/Tank Attach Strips - Question Reply with quote
yep, start here: http://www.rvproject.com/20020716.html Dan Checkoway's project web site
Dan has done a wonderfull job in documenting his project. I bought his CD and refer to it all the time. You will want to review his approach to not only the le/tank joint but
more importantly (and useful) read his sections on the tank Z brackets.
Dave
[quote] --
sa300(at)uniserve.com
PostPosted: Sat Sep 09, 2006 2:38 pm    Post subject: Leading Edge/Tank Attach Strips - Question Reply with quote
Yes those are the strips to use and building the tanks is NOT an issue. Quite listing to people about how bad they are to build, just put it in your mind that the prop-seal can be a bit messy and get on with it. Then it won't be so bad.
Scott R. Shook wrote: [quote] Leading Edge/Tank Attach Strips - Question
Hey all,
Thanks for the help
Scott & Jenni
RV-7A N696JS
AltonD
PostPosted: Sat Sep 09, 2006 3:55 pm    Post subject: Re: Leading Edge/Tank Attach Strips - Question Reply with quote
Drawing 12, Section F-F. Note on the left hand side of section F-F. It's buried in there, but you have the right piece.
AltonD
Waiting on the slow build fuselage to deliver
fvalarm(at)rapidnet.net
PostPosted: Sat Sep 09, 2006 5:51 pm    Post subject: Leading Edge/Tank Attach Strips - Question Reply with quote
To those that are new to this,
When Norman said, "just put it in your mind that the prop-seal can be a bit messy and get on with it." He actually meant "flamemaster" or "PRC" (among other names) fuel tank sealant. Don't use prop-seal, whatever that is. And I agree with Norman, that the tanks are not bad to do. I would do them again if I ever build another plane . Two guys two sessions per tank. Build on.
Bevan
RV7A Finishing kit.
[quote] [b]
PostPosted: Sat Sep 09, 2006 6:28 pm    Post subject: Leading Edge/Tank Attach Strips - Question Reply with quote
Looks like I made a few spelling errors in the last note. I meant Pro-Seal or PRC etc. like Van's supplies.
Thanks for the correction Bevan.
B Tomm wrote: [quote]
Bevan
RV7A Finishing kit.
