Chafing Tape
Dave Pelletier
PostPosted: Mon Jan 23, 2006 9:20 am    Post subject: Chafing Tape Reply with quote
AzDave
firebug
PostPosted: Mon Jan 23, 2006 10:30 am    Post subject: Re: Chafing Tape Reply with quote
I understand that chafing tape goes on the rough areas under the fabric but you also put it on the exterior too, it can also be refered to as surface tape. The function is two fold, one it strengthens the area but I think most importantly it guards against chafing the fabric when the high spot hits an object. It is simply 2 - 3 inches wide usually with pinked edges. It is glued to the surface like it is over the ribs of the wings.
