The ultimate door latch
Goto page Previous  1, 2, 3
deruiteraircraftservices(
PostPosted: Tue Jan 24, 2006 2:50 am    Post subject: The ultimate door latch Reply with quote
Doesn't it do the job? At no extra cost?
sbukolt(at)dstewart.com
PostPosted: Tue Jan 24, 2006 6:28 am    Post subject: The ultimate door latch Reply with quote
I'm a rookie, so please excuse the ignorant question:
What is wrong with using seatbelt as a gust lock? From my novice
perspective it seems ideal:
1. Pretty fool proof if you use the left seatbelt. You can't sit in the
left seat with the "gust lock" in place, eliminating the potential for
error.
2. Seatbelts are handy and not in use for other purposes when gust locks
are needed (i.e. when the plane is not in use).
3. They work just as well as something you must build or pay
additionally for.
Please help me understand how this is inappropriate.
Scott
Scott Bukolt
RV-10 #40541 (Empenage kit arrived 1/23/06)
Tdawson(at)avidyne.com
PostPosted: Tue Jan 24, 2006 7:02 am    Post subject: The ultimate door latch Reply with quote
I guess it's a matter of taste. Something like using tools only for the
jobs they were intended. You can use a screwdriver as a crowbar, too,
if you want . . .
Then there's the aesthetics . . .
TDT
pilotdds(at)aol.com
PostPosted: Tue Jan 24, 2006 7:20 am    Post subject: The ultimate door latch Reply with quote
There is not a cessna on the ramp I cant unlock with a paperclip
PostPosted: Tue Jan 24, 2006 7:31 am    Post subject: The ultimate door latch Reply with quote
So if we renamed seatbelts simply "retention devices" they would become
appropriate and tasteful tools for use as gust locks?
I figured there was some integrity or safety issue. Perhaps I'm too
pragmatic. Also I thought of another important reason Seatbelts make
good locks. Weight. Why carry an extra ounce around with you if there is
no need?
Not trying to be argumentative, just learning.
sb
rvbuilder(at)sausen.net
PostPosted: Tue Jan 24, 2006 7:50 am    Post subject: The ultimate door latch Reply with quote
This is an area a gave a very small amount of thought to so far. Reason being because there is no way I'm going to leave a 50k panel with an unlocked door. I am more than happy to replace a broken window or even an entire door if it might give an extra few minutes of work to a potential thief. Thieves don't want to spend anytime in the open and will just walk away from a challenge 95% of the time. But if they can simply walk up to an aircraft and climb in, shutting the door behind them, they will almost certainly pick that aircraft as a target.
So I will use some method to restrict access to my -10 one way or another. In addition I am planning on integrating the door warning system with a run of the mill auto alarm. I'm sure some people are giggling but for less than the price of topping one of the tanks I can put in a loud alarm that will most certainly deter someone from targeting it. Remember, deterrence is the best answer in almost all occasions. An easy target has a much, much higher probability of being stolen. There used to be a show on Discovery, don't recall the name, in which a pair of reformed thieves would go around to peoples homes and show them just how quickly they could steal them blind. In the show the one thing they always tried to re-enforce was that a thief will not spend any amount of time at a house that they can not easily access and they would almost always keep walking if they knew it was alarmed.
Just keep in mind the whole goal is deterrence because nothing will keep someone from breaking in if they want to. You just need to make it a less attractive target. We have a lot of theft around my in-laws ranch but no one has ever attempted to break into my workshop. The primary reason is I made sure everyone around knows there is an alarm system on it that emails and pages a half a dozen people. I then made sure that a few of the employees saw it in action.
I may look like a dork when my aircraft flashes it's position lights when the alarm arms but I will sleep well knowing it will most likely be in the exact same condition the next morning, especially if some of you with no locks park near by. Wink
My $0.02 on the matter.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com on behalf of Tim Olson
Sent: Mon 1/23/2006 9:54 PM
Subject: Re: Re: The ultimate door latch
Gust lock = seat belt wrapped over the stick.
I'm on the fence regarding the door lock issue. Of course,
I'd love to have a door lock. But, Van's didn't make one, and
it gave me a chuckle to read the email that suggested that
they'd listen to our input and decide to offer them. Perhaps
they would, but they'd be an add on cost item, for sure.
I myself still think a good idea is to use their door
latch warning system as a combination door latch warning
and alarm system. People don't look too hard at
a car with beeping horn and blinking lights, but I bet
it would gain some quick attention on the ramp....and it would
prevent someone from doing extreme damage to your plane by
trying to pry open your locked doors.
That's only worth .01 cent, so I won't even give my .02. Wink
Eric Panning wrote:
I think Van's should provide it as an option/upgrade
for the reasons Steve stated. I may not be so lucky as
to have a hanger initially + I plan on traveling, etc.
Not locking the plane is a bad solution. I think the
insurance company would take issue with this approach
when filing a claim. Also, what if they run off with
the plane or worse yet fly it into a TFR or ADIZ, etc?
I wouldn't want to have to explain to homeland
security that the plane was unlocked....
While Van's are at it, perhaps they can work on a gust
lock for the stick?
Eric
DO NOT ARCHIVE
>I've seen it discussed here before... but consider
>the damage that
>someone will do to your locked door to get at to
>your $35,000 panel.
>It's arguably better to minimize the collateral
>by not locking the door. Perhaps a well secured
>cover (so they can't
>tell what's in the plane to start with) is a better
>approach.
>Jeff Carpenter
>40304
>Top Skinning the Wings
>On Jan 23, 2006, at 1:21 PM, steveadams wrote:
>><dr_steve_adams(at)yahoo.com>
>>Isn't it common sense that a plane with a mission
>profile like the
>>RV-10 should have been designed with locking door
>latches? It's not
>>a hanger queen designed to get pulled out for a
>short joy ride
>>every Sunday afternoon. Maybe instead of trying
>to jury rig a
>>lock, or debating sending $700 overseas for
>something that looks
>>good but may or may not work as specified, a
>little pressure on
>>Vans from the builders would encourage them to
>design and build a
>>locking latch that could at least be ordered as an
>option. They
>>seem to have the resources to get something like
>that made up
>>pretty quickly if they get the impression that it
>is important to
>>their customers. Also, in general their prices are
>usually pretty
>>reasonable. Just a suggestion.
>>Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=6231#6231
>browse
>Subscriptions page,
>FAQ,
>Admin.
jjessen(at)rcn.com
PostPosted: Tue Jan 24, 2006 8:15 am    Post subject: The ultimate door latch Reply with quote
I would like to have a keyed door, thank you. It's a very odd thing to have
a $100,000 plus item with $35,000 plus worth of very saleable gear inside
(and these radios do get stolen) that can be flown away (these planes do get
stolen) and not at least give the builder an option to lock it when you are
parked out on the ramp. Insurance again? No IFR? No locks? I also will
have a throttle lock. The only hanger I can really count on is my own.
As for gust prevention, a seat belt is always usable, and I'm not against
using one, but I'm liking the idea of the items that were used out on the
flying surfaces and pictured a few posts ago. Got to find out more.
Finally, this RV-10 builders site is awfully quiet. This must be one very
simple plane to put together. Funny how good instructions and CNC matched
holed technology can make builders more productive. I think after the -10
is together I'll just have to go build a -3.
John Jessen
~ 328 (putting together my web site and bouncing back and forth from
elevators to tailcone)
Tim(at)MyRV10.com
PostPosted: Tue Jan 24, 2006 10:51 am    Post subject: The ultimate door latch Reply with quote
You've got me thinking..... Maybe I should just buy a pit-bull,
doberman, or maybe even a monitor lizard.
PS: I like the idea of those flashing position lights when you
arm the alarm. One other additional thing that might be nice is
a little surface mount LED mounted on/by the door that has
a decal with the label "Alarm Armed". Just that alone would
be a deterrent to many. When I owned a business in a mall,
during a rash of breakins, we put in a simple door open alarm on
the back door, and a little green LED that said ARMED next to
it. Both neighbors got hit, but we didn't.
Tim Olson -- RV-10 #40170
DO NOT ARCHIVE
as a target.
it was alarmed.
action.
Michael Sausen -10 #352 Fuselage
Sent: Mon 1/23/2006 9:54 PM To: rv10-list(at)matronics.com Subject: Re:
I'm on the fence regarding the door lock issue. Of course, I'd love
to have a door lock. But, Van's didn't make one, and it gave me a
chuckle to read the email that suggested that they'd listen to our
input and decide to offer them. Perhaps they would, but they'd be an
add on cost item, for sure. I myself still think a good idea is to
use their door latch warning system as a combination door latch
warning and alarm system. People don't look too hard at a car with
beeping horn and blinking lights, but I bet it would gain some quick
attention on the ramp....and it would prevent someone from doing
extreme damage to your plane by trying to pry open your locked doors.
That's only worth .01 cent, so I won't even give my .02. Wink Tim
Eric Panning wrote:
> <ericmpmail-rv10(at)yahoo.com>
> I think Van's should provide it as an option/upgrade for the
> reasons Steve stated. I may not be so lucky as to have a hanger
> Not locking the plane is a bad solution. I think the insurance
> company would take issue with this approach when filing a claim.
> Also, what if they run off with the plane or worse yet fly it into
> a TFR or ADIZ, etc? I wouldn't want to have to explain to homeland
> While Van's are at it, perhaps they can work on a gust lock for the
> stick?
> Eric
> DO NOT ARCHIVE
>> I've seen it discussed here before... but consider the damage
>> that someone will do to your locked door to get at to your
>> $35,000 panel. It's arguably better to minimize the collateral
>> damage to your plane by not locking the door. Perhaps a well
>> secured cover (so they can't tell what's in the plane to start
>> with) is a better approach.
>> Jeff Carpenter 40304 Top Skinning the Wings
>> profile like the
>> latches? It's not
>> short joy ride
>> to jury rig a
>> little pressure on
>> design and build a
>> option. They
>> that made up
>> is important to
>> usually pretty
>> browse Subscriptions page, FAQ,
>> Admin.
PostPosted: Tue Jan 24, 2006 11:00 am    Post subject: The ultimate door latch Reply with quote
It would be cute to trigger the strobes if someone trips the alarm . . .
TDT
jjessen(at)rcn.com
PostPosted: Tue Jan 24, 2006 11:20 am    Post subject: The ultimate door latch Reply with quote
I like the LED idea! Simple. Cool looking if in cobalt blue.
jhstarn(at)verizon.net
PostPosted: Tue Jan 24, 2006 12:52 pm    Post subject: The ultimate door latch Reply with quote
Just thought I'd trim posts of verbiage & Do Not Archive.
I mean we were working on page FOUR of a single thread.
The sky is falling, the sky is falling. "We are all going to die"
Not me I'm taking the Rocket (N561FS HRII) to the moon, no one has ever died
on the moon so it must be a safe place...right ? ? 8*) KABONG
PostPosted: Tue Jan 24, 2006 1:03 pm    Post subject: The ultimate door latch Reply with quote
Want/need to steal a car ? ? Walk thru "Wal-Mart" parking lot & look for
the unlocked car with the keys in it. Lock the door, windows up, red
flashing on something and the opportunistic joyriding car thief was keep
walking & looking. It's too easy to find one with the keys in it. Do Not
Archive KABONG (ex-Det. Sgt Fontana PD)
jjessen(at)rcn.com
PostPosted: Tue Jan 24, 2006 1:12 pm    Post subject: The ultimate door latch Reply with quote
This thread is fine for me. I have no clue what you're talking about.
LIKE2LOOP(at)aol.com
PostPosted: Tue Jan 24, 2006 1:21 pm    Post subject: The ultimate door latch Reply with quote
In a message dated 1/23/2006, Tim(at)MyRV10.com writes:
People don't look too hard at a car with beeping horn and blinking lights, but I bet
it would gain some quick attention on the ramp....and it would prevent someone from doing extreme damage to your plane by trying to pry open your locked doors.
Makes me think... i always wanted a horn in my plane!
    As for prying doors open, prior to 9/11, the local flight school NEVER locked their planes so the plane would not get damaged from a thief and a crow bar. I think they have to lock them now.  The worst they would have to do was buy a new radio, far simpler then an airframe repair and a 337 report. .
DO NOT ARCHIVE
PostPosted: Tue Jan 24, 2006 1:27 pm    Post subject: The ultimate door latch Reply with quote
You mean, no one has ever died on the moon - THAT WE KNOW ABOUT! : )
TDT
do not archive, please
Page 3 of 3
