Dsyvert(at)aol.com Guest
Posted: Sun Oct 08, 2006 2:27 pm Post subject: Clecoing nose of VS |
Group,
Does anyone have any tricks on clecoing the nose of the VS? It seems a little tight to me. I've been able to do one entire side, plus the rear ribs and both spars of the other side but the nose ribs of the one side are tight. My thoughts are to take every thing apart and just do the other sides ribs. However, that is just putting off the tightness to dimpling. I am thinking about putting a 2x4 across the nose and the back side and then using a "come-along" to take up the slack. I'm afraid this will just dent the sheet. Any ideas or tricks?
Dave Syvertson
rene(at)felker.com Guest
Posted: Sun Oct 08, 2006 3:30 pm Post subject: Clecoing nose of VS |
Here is a tip from Tim’s site.
http://www.myrv10.com/tips/vstabtips.html
I did not have this info when I started and I have a dented VS to prove it.
Rene'
801-721-6080
Posted: Sun Oct 08, 2006 4:38 pm Post subject: Clecoing nose of VS |
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sun Oct 08, 2006 6:36 pm Post subject: Clecoing nose of VS |
I think you will find that you need to do a little bending of the forward flange edge on the leading edge ribs at the forward point otherwise you will dent the skin trying to force it around the points. See Tim Olson's tips at http://www.myrv10.com/tips/gotchas.html for a better explanation.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
Roadster
Posted: Sun Oct 08, 2006 11:34 pm Post subject: Clecoing nose of VS |
| Quote: | > Does anyone have any tricks on clecoing the nose of the VS? It seems a
ribs
| Quote: | > and both spars of the other side but the nose ribs of the one side are
tight.
Grind those nose ribs back to the minimum edge distance, and then round the
corners. Here's my write-up and photos after the modification was
complete...
http://www.mykitlog.com/users/display_log.php?user=Roadster&project 10&cate
gory=1857&log 339&row 9
Sam Williams
#40619
Rudder Assembly
_________________ Empennage
My KitLog Pro Website |
Roadster
Posted: Sun Oct 08, 2006 11:44 pm Post subject: Clecoing nose of VS |
Sorry about the garbled link. Here's an alternative route to the information...
Click the "Empennage" link on my KitLogPro website....
http://www.mykitlog.com/Roadster
And then go to the entry on 09-19-2006 entitled "Modify Ribs to Minimize Skin Buckling" for my write-up and photos.
Sam Williams
#40619
Rudder Assembly
glastar(at)gmx.net Guest
Posted: Mon Oct 09, 2006 12:51 am Post subject: Clecoing nose of VS |
To all,
to avoid garbled links just embed them between < and >.
Werner
Samuel M. Williams wrote:
| Quote: | Sorry about the garbled link. Here's an alternative route to the
information...
Sam Williams
#40619
Rudder Assembly
bsponcil(at)belinblank.or Guest
Posted: Mon Oct 09, 2006 6:05 am Post subject: Clecoing nose of VS |
Tight nose ribs seems to be a common affliction in the Vans kits. My VS (along with many others) has a skin dent from my not knowing. I have since been a little more aggressive with the deburring wheel when it comes to the nose ribs and it's worked out better.
-Brian
#40497
N211BD
Iowa City, IA
jjessen
Posted: Mon Oct 09, 2006 8:16 am Post subject: Clecoing nose of VS |
That's a nice job. I rounded the corners, as seen here.
<http://www.soundingsresearch.com/RV-10/Empennage/HS/HS07.htm> Worked okay,
but I dunno, may like your technique better.
John Jessen
#40328 (riveting tailcone)
johngoodman
Posted: Mon Oct 09, 2006 3:09 pm Post subject: Re: Clecoing nose of VS |
Amen! You guys have to promise me you'll never notice by VS "bumps".
John
[quote="bsponcil(at)belinblank.or"]Tight nose ribs seems to be a common affliction in the Vans kits. My VS (along with many others) has a skin dent from my not knowing. I have since been a little more aggressive with the deburring wheel when it comes to the nose ribs and it's worked out better.
-Brian
#40497
N211BD
Iowa City, IA
_________________ #40572 Phase One complete in 2011 |
Vern(at)teclabsinc.com Guest
Posted: Tue Oct 10, 2006 8:08 am Post subject: Clecoing nose of VS |
John,
If it makes you feel any better Van's factory planes have VS bumps.
Vern
Deems Davis
Posted: Tue Oct 10, 2006 12:41 pm Post subject: Clecoing nose of VS |
So did both of the '05 Colorado OSH award winners.
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/
Vern W. Smith wrote:
John,
Vern
Posted: Tue Oct 10, 2006 1:15 pm Post subject: Clecoing nose of VS |
So, it looks like I did mine correctly......with dents.
Rene' Felker
40322
Panel/finish and a lot inbetween
Posted: Tue Oct 10, 2006 1:38 pm Post subject: Clecoing nose of VS |
Their like dimples on a golf ball they make it fly better:)
Sorry just couldn't resist,
Vern (#324)
