Beech-List Digest: 3 Msgs - 10/12/06
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List
stu_brown(at)juno.com
PostPosted: Sat Oct 14, 2006 5:09 am    Post subject: Beech-List Digest: 3 Msgs - 10/12/06 Reply with quote
Use care when removing the drain valve from your tank. It is possible
to rip or crack the nipple from an old tank that has lost it's elasticity.
I checked the tanks in my G-35, the bladders were manufacturered in
September 1955. Wish me luck.
Someone posted he changed the O-rings in the Curtis drain valve. Where
did you get the parts? I did not know Curtis offered replacement parts.
Stu Brown
Today's complete Beech-List Digest can also be found in either of the
of the Beech-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/beech-list/Digest.Beech-List.2006-10-12.html
Text Version:
http://www.matronics.com/digest/beech-list/Digest.Beech-List.2006-10-12.txt
Beech-List Digest Archive
Total Messages Posted Thu 10/12/06: 3
Today's Message Index:
1. 05:16 AM - Re: cleveland brakes and gear doors (Masterson, Fred)
2. 07:42 AM - Re: Main gear doorsMain gear doors (Murray Randall)
3. 08:18 AM - Re: cleveland brakes and gear doors (Rob Breitbarth)
________________________________ Message 1
_____________________________________
Time: 05:16:11 AM PST US
From: "Masterson, Fred" <Fred.Masterson(at)airliquide.com>
Subject: RE: cleveland brakes and gear doors
If you hold the drain to one side you can use a thin screwdriver to loosen
the clamp.
The hardest part is holding it to reinstall the drain.
I pulled both and put new o rings in last year.
Fred Masterson
- The Matronics Beech-List Email Forum -
http://www.matronics.com/Navigator?Beech-List
rob87b(at)earthlink.net
PostPosted: Sat Oct 14, 2006 6:36 am    Post subject: Beech-List Digest: 3 Msgs - 10/12/06 Reply with quote
I got the drain valves from the beech dealer. No luck on replacement o-rings. Curtis does not supply them. Some people are using regular 0-rings, not the special shape Curtis. Don't know how they work. I have replaced two bladders so far. The other two are 1955 vintage. They are the ones that have leaky valves. The seal was gone in the one valve I just replaced. The other looks like it will be the same.
Watch close and replace if starts giving you trouble. It will only get worse. I was just on a cross country trip when one would not stop leaking. Had to defuel an aux tank to stop the leak.
rob.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List All times are GMT - 8 Hours
