Ed Anderson
Posted: Thu Jan 26, 2006 5:27 am Post subject: Denied Access to National Airspace System |
If your aircraft registration information with the FAA is not up to date, you might want to update it before Feb 1 based on this notice filed in the Federal Register recently.
Aircraft owners and operators must ensure their aircraft registration information and security waivers are properly completed and up to date by Feb. 1, 2006, or they "may be denied access" to the National Airspace System, the FAA said in a notice published in the Federal Register on Friday.
If you want to check - go to this webpage and type in your N number. This data base contains the N numbers of those folks needing to update their registration information (mainly address). If your number is in it - it will respond with what you need to do to correct it. If your number is not in it you will get a " can't find" response.
http://registry.faa.gov/aircraftinquiry/NNum_inquiryUN.asp
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
| - The Matronics RVSouthEast-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
sawad13(at)msn.com Guest
Posted: Thu Jan 26, 2006 6:19 am Post subject: Denied Access to National Airspace System |
i typed in my n number and this came back
Incorrect Address Records
N-Number Inquiry Results
N259JB is not Found
Does this mean I need to do something????????????
Ron Awad
Quote: | From: "Ed Anderson" <eanderson(at)carolina.rr.com>
Reply-To: rvsoutheast-list(at)matronics.com
To: <rvsoutheast-list(at)matronics.com>
CC: "Rotary motors in aircraft" <flyrotary(at)lancaironline.net>
Subject: Denied Access to National Airspace System
Date: Thu, 26 Jan 2006 08:26:05 -0500
Friday.
Ed Anderson
Matthews, NC
Ed Anderson
Posted: Thu Jan 26, 2006 6:42 am Post subject: Denied Access to National Airspace System |
Ron,
My understanding is that if your N number is NOT found in this "bad boy"
data base, then you are OK. So based on that I would say you are OK with
N259JB. If you number was found then the incorrect address is probably the
thing that needed to be corrected.
Ed
Matthews, NC
Mike Munn
Posted: Thu Jan 26, 2006 8:24 am Post subject: Denied Access to National Airspace System |
Ron,
On that same screen, click on Aircraft Inquires, N-number at the upper
left. You will see the same screen, however right above where you input
your N number, it will say FAA Registry N number inquiry. Input you N
number, this will give you all the info that the FAA has on your aircraft.
If it is all correct, your okay, if not you need to correct the info.
Mike Munn
RV8
The information transmitted is intended only for the person
or entity to which it is addressed and may contain proprietary,
business-confidential and/or privileged material.
If you are not the intended recipient of this message you
are hereby notified that any use, review, retransmission,
dissemination, distribution, reproduction or any action taken
in reliance upon this message is prohibited. If you received
this in error, please contact the sender and delete the
material from any computer. Any views expressed in this message
are those of the individual sender and may not necessarily reflect
the views of the company.
