hawkins(at)cms.udel.edu Guest
Posted: Mon Oct 30, 2006 9:18 am Post subject: Nose wheel problems |
Hey all-
Well, no luck in selling N2760B here in Delaware - so thinking I'll just
start flying her. Have a couple of well qualified pilots with the
Commander here at Georgetown.
Ran into a problem this weekend though. Know the nose wheel steering is
"tricky" - but we're having a problem with it turning hard left and not
being able to get it centered again. Even with full right rudder and
full throttle on the left engine.
When you shut down, you can go out and turn it to center by hand - very
little (if any) pressure on the ram.
Checked for air in cylinder - nothing.
Looking at the hydraulic drawing - could the nose wheel steering by-pass
valve be bad? Such that fluid just passes through valve rather than to
the ram?
Funny that it only goes hard left - never hard right? At least not yet!
Hydraulic pressure is running a bit high (1200 psi - just shy of the
relief) and we need to adjust down to be 900 - 1100 as I understand.
Only hydraulic pump on the left engine.
No problem with flap or gear - just "quick" because of the slightly high
pressure.
At about 1000 RPM we can hear a bit of hydraulic "chatter" down between
the seats where the hand pump selector valve and relief valve are. It
goes away at around 1500 RPM.
Just trying to give you all the symptoms in case there's a connection.
All hydraulic related, but hard left on the nose wheel is the real
problem right now.
Could it be "operator error" - something we're doing wrong in handling
her on the ground? Our pilot with lots of time in the Commander has
never had the severe "hard left" problem in his bird - though very
familiar with the tricky steering.
All suggestions appreciated.
Matt
Matthew Hawkins
Director, Marine Ops
R/V HUGH R. SHARP
302-645-4341
FAX: 302-645-4006
hawkins(at)udel.edu
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
brcamp(at)windows.microso Guest
Posted: Mon Oct 30, 2006 9:57 am Post subject: Nose wheel problems |
Sounds to me more like a worn bolt/bushing. They are *very* critical.
Bruce
N4186B
Posted: Mon Oct 30, 2006 10:19 am Post subject: Nose wheel problems |
One other thought. Might want to check the main gear for play.
Bruce Campbell
N4186B AC52
Skyhawkc-172
Posted: Mon Oct 30, 2006 11:46 am Post subject: Nose wheel problems |
what would main gear play mean or what affect would this cause ? we have had the same problem steering hard one way or the other, but I know what its from...40mph crosswinds while taxxing : )
[quote]-------------- Original message --------------
From: Bruce Campbell <brcamp(at)windows.microsoft.com>
[quote] --> Commander-List message posted by: Bruce Campbell
Bruce Campbell
N4186B AC52
YOURTCFG(at)aol.com Guest
Posted: Mon Oct 30, 2006 6:08 pm Post subject: Nose wheel problems |
In a message dated 10/30/2006 9:19:34 A.M. Pacific Standard Time, hawkins(at)cms.udel.edu writes:
| Quote: | Even with full right rudder and
I am sure this is a typo, because you know the rudder will not steer the airplane. It may be that the shimmy dampener is dirty. Take some brake cleaner (found in aerosol cans at places like NAPA) and hose down the shimmy dampener. Next check the rigging on the shimmy damper (as per the manual). If the steering is working one direction, it is not the steering cut out valve. Do the brakes work normally?? You can check for pressure at the cylinder by building pressure in the system, then depress the pedal to steer and crack the appropriate line to the steering cylinder. If there is no pressure there, work backward until you get pressure. The chattering is probably low pressure in the accumulator. or a faulty unloading valve, it is mounted blow the floor next to the hand pump. jb
amg3636(at)hotmail.com Guest
Posted: Mon Oct 30, 2006 6:31 pm Post subject: Nose wheel problems |
This is a test. I posted a reply several hours ago have not seen it yet.
Roland
| Quote: | From: "Matthew J. Hawkins" <hawkins(at)cms.udel.edu>
Reply-To: commander-list(at)matronics.com
Subject: Nose wheel problems
Date: Mon, 30 Oct 2006 12:17:32 -0500
Hey all-
the ram?
pressure.
problem right now.
Matt
Matthew Hawkins
R/V HUGH R. SHARP
302-645-4341
FAX: 302-645-4006
hawkins(at)udel.edu
Live Search!
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27556 Location: Livermore CA USA
Posted: Mon Oct 30, 2006 6:39 pm Post subject: Nose wheel problems |
Roland,
Doesn't look like it even made it to the Matronics Email Server. Your "test" message is the only message I'm finding in the logs.
Best regards,
Matronics Email List Admin
At 06:29 PM 10/30/2006 Monday, you wrote:
Roland
>Hey all-
>the ram?
>pressure.
>problem right now.
>Thanks,
>Matt
>Matthew Hawkins
>R/V HUGH R. SHARP
>302-645-4341
>FAX: 302-645-4006
>hawkins(at)udel.edu
Live Search!
_________________ Matt Dralle
Jim Addington
Joined: 09 Jan 2006 Posts: 62 Location: Denton, Texas
Posted: Mon Oct 30, 2006 7:33 pm Post subject: Nose wheel problems |
Matt,
I don't know if the system is any where near the same as my 500A, but, I had
a problem one time where I had put the gear handle down and had three green
but when we landed and put in right rudder and brake the plane went left.
What I found was the handle was down and the gear was down with green lights
but the handle was not locked down. What I think happened was the ports were
not lined up properly and the right side brake and steering was putting
pressure in the left side. Just my thought which is usually wrong, but,
thought I would pass it on any way.
Jim Addington
N444BD
500A
Hey all-
the ram?
pressure.
problem right now.
Matt
Matthew Hawkins
R/V HUGH R. SHARP
302-645-4341
FAX: 302-645-4006
hawkins(at)udel.edu
Posted: Mon Oct 30, 2006 10:52 pm Post subject: Nose wheel problems |
I'll tell you what I did to fix mine.
I made a hose to fit the fitting on the brake assembly, then put a 1500 lb
oil gauge on the other end. Take off the cover under the brake valves.
Attach hose to brake fitting. Pump up the hand valve to about 900 lbs. There
should be no pressure to the brake assembly. ( Yours probably has some
pressure) Adjust the fitting on the brake valve to let pressure show on the
gauge. pump hand valve back up as needed to maintain good pressure. It needs
to be adjusted so no pressure is on the gauge unless you push the brake
pedal, ( 500 - 700 lbs I think). I was about to sell my plane because It
would not steer one way, I thought it was just me. I did this , and in 5
minutes it was like new.Of course this may not be your problem, but it's
worth a try. I think I spent $40.00 on my gauge. My 500 has Clevland brakes,
I assume yours has the fitting to attach to.
Good luck,
Roland
To: <commander-list(at)matronics.com>
Hey all-
the ram?
pressure.
problem right now.
Matt
Matthew Hawkins
R/V HUGH R. SHARP
302-645-4341
FAX: 302-645-4006
hawkins(at)udel.edu
Find a local pizza place, music store, museum and more…then map the best
route! http://local.live.com?FORM=MGA001
br549phil(at)mindspring.c Guest
Posted: Tue Oct 31, 2006 7:46 am Post subject: Nose wheel problems |
When I brought mine home had a similar problem.
Most of the fault was with somebody "overshimming " the steering collar on
the nose wheel so that it had lots of friction.
The second part of the fix was to follow the brake valve pressure
adjustment procedure in the maintenance manual.
After doing these it steers like a dream.
Phil Stubbs
| Quote: | [Original Message]
Date: 10/30/2006 10:37:12 PM
Subject: Re: Nose wheel problems
<jtaddington(at)charter.net>
Matt,
had
| Quote: | a problem one time where I had put the gear handle down and had three
green
| Quote: | but when we landed and put in right rudder and brake the plane went left.
lights
| Quote: | but the handle was not locked down. What I think happened was the ports
were
| Quote: | not lined up properly and the right side brake and steering was putting
Jim Addington
N444BD
500A
> Hey all-
> the ram?
> pressure.
> problem right now.
> Thanks,
> Matt
> Matthew Hawkins
> R/V HUGH R. SHARP
> 302-645-4341
> FAX: 302-645-4006
> hawkins(at)udel.edu
Skyhawkc-172
Posted: Tue Oct 31, 2006 12:00 pm Post subject: Nose wheel problems |
Heres a MS flight sim vid for those whom haven't flown their commanders for a bit.
http://video.google.com/videoplay?docid=4390310129931723937&q=aero+commander
| Quote: | --> Commander-List message posted by: ""
Phil Stubbs
> [Original Message]
> From: Jim Addington
> To:
> --> Command er-Lis t message posted by: "Jim Addington"
> Matt,
had
green
lights
were
> Jim Addington
> N444BD
> 500A
[quote] >
> > --> Commander-List message posted by: "Matthew J. Hawkins"
> > Hey all-
> > Checked for air in cy linder - nothing.
> > the ram?
> > pressure.
> > goes away at around 1 500 RP M.
> > problem right now.
> > Thanks,
> > Matt
> > Matthew Hawkins
> > R/V HUGH R. SHARP
> > 302-645-4341
> > FAX: 302-645-4006
> > hawkins(at)udel.edu
& gt; &g List
BillLeff1(at)aol.com Guest
Posted: Tue Oct 31, 2006 4:06 pm Post subject: Nose wheel problems |
Check your nose wheel steering collar for wear on the upper and lower surfaces. Also the strut could have to much wear. If it has too much clearance it will cock when steering one direction.
Bill Leff
Jim Addington
Posted: Tue Oct 31, 2006 7:41 pm Post subject: Nose wheel problems |
That was a nice video, really enjoyed it.
Jim Addington
N444BD
500A
rsrandazzo(at)precisionma Guest
Posted: Tue Oct 31, 2006 7:52 pm Post subject: Nose wheel problems |
Jim-
It was.... tis a shame that even virtual commanders are starting to show signs of corrosion tho... hahahah
Rob
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington
Sent: Tuesday, October 31, 2006 19:41
Jim Addington
N444BD
500A
Jim Addington
Posted: Tue Oct 31, 2006 8:15 pm Post subject: Nose wheel problems |
I noticed, it was sad.
Jim
Skyhawkc-172
Posted: Tue Oct 31, 2006 11:29 pm Post subject: Nose wheel problems |
no corrosion here...
MS Flight sim
http://www.aoc.noaa.gov/Snow%20Survey%20HI-RES.wmv
Jim
Skyhawkc-172
Jim Addington
Posted: Wed Nov 01, 2006 7:09 am Post subject: Nose wheel problems |
I saw this last year and lost it when my computer email went south on me. I really did like it and I now have it again.
Jim
bowing74(at)earthlink.net Guest
Posted: Wed Nov 01, 2006 12:20 pm Post subject: Nose wheel problems |
One kool dude!
bilbo
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of skyhawkc-172(at)comcast.net
Sent: Wednesday, November 01, 2006 2:40 AM
OK, the real thing.
http://www.aviationspeakers.com/Speakers/bob-hoover.php
MS Flight sim
Jim
Posted: Thu Nov 02, 2006 4:12 am Post subject: Nose wheel problems |
Matt,
It finally came through.
Roland
| Quote: | From: Matt Dralle <dralle(at)matronics.com>
Subject: RE: Nose wheel problems
Date: Mon, 30 Oct 2006 18:38:39 -0800
Roland,
Best regards,
<amg3636(at)hotmail.com>
>Roland
>>Hey all-
>>the ram?
>>pressure.
>>problem right now.
>>Thanks,
>>Matt
>>Matthew Hawkins
>>R/V HUGH R. SHARP
>>302-645-4341
>>FAX: 302-645-4006
>>hawkins(at)udel.edu
>_________________________________________________________________
>Live Search!
