deanpichon(at)msn.com Guest
Posted: Fri Nov 03, 2006 4:48 pm Post subject: Gapping Spark Plugs- The Rest of the Story |
Hi All,
I had no idea my innocent post would generate so much interest and consume
so much bandwidth. In hindsight, I should have posted a more detailed
question or perhaps nothing at all.
In my quest perform as much prep work as possible for my annual in my
basement rather than at the airport, I had considered gapping my shiny new
plugs at home, prior to going to the airport. I decided I didn't want to
open the protective package only to find that all the plugs were within
specification. Thanks to the person who indicated the plugs are gapped and
generally within spec.
With that knowledge, I left for the airport this morning, armed with my gap
gauge and gap setting tool and 8 new spark plugs. Much to my pleasure, I
found all plugs within tolerance and installed them quite quickly.
It was never about whether I had to check the gaps, but rather the liklihood
that would have have to re-set the gaps. Thanks to all. I have learned
much from this experience.
Dean Pichon
----Original Message Follows----
Reply-To: rv-list(at)matronics.com
Subject: Gapping Champion Spark Plugs
Date: Thu, 02 Nov 2006 17:47:30 -0500
Hi All,
I just received some new Champion spark plugs and would like to know if they
come pre-gapped. I am reluctant to open the moisture-proof packaging to
check. Does anyone out there know whether or not these arrive ready to
install?
Dean Pichon
Live Search!
Use your PC to make calls at very low rates
https://voiceoam.pcs.v2s.live.com/partnerredirect.aspx
Tim(at)MyRV10.com Guest
Posted: Fri Nov 03, 2006 7:25 pm Post subject: Gapping Spark Plugs- The Rest of the Story |
Tonight I installed 12 new plugs in my IO-540. I bought Iridium
fine wire aircraft plugs for the bottoms, and I got a great bulk
deal on some exact replacement Denso W24EMR-C's for the Lightspeed
ignited top plugs. I found every one of the Iridium plugs was
either exactly at, or within 1 thousandth over the spec for the
aircraft plugs. I found every one of the Densos was either right
at spec, or perhaps gapped maybe .001 undersized...but by the
time I squished in the feeler gauge they were right on.
I'll still check the gaps each time before I install them, but
so far on cars/snowmobiles/airplanes I've been lucky enough to
have most every plug I've ever grabbed be within spec
right out of the box.
Dean Pichon wrote:
Hi All,
consume so much bandwidth. In hindsight, I should have posted a more
detailed question or perhaps nothing at all.
new plugs at home, prior to going to the airport. I decided I didn't
want to open the protective package only to find that all the plugs were
within specification. Thanks to the person who indicated the plugs are
gapped and generally within spec.
gap gauge and gap setting tool and 8 new spark plugs. Much to my
pleasure, I found all plugs within tolerance and installed them quite
quickly.
liklihood that would have have to re-set the gaps. Thanks to all. I
have learned much from this experience.
Dean Pichon
Hi All,
they come pre-gapped. I am reluctant to open the moisture-proof
packaging to check. Does anyone out there know whether or not these
arrive ready to install?
Dean Pichon
Live Search!
bicyclop(at)pacbell.net Guest
Posted: Fri Nov 03, 2006 9:52 pm Post subject: Gapping Spark Plugs- The Rest of the Story |
Oh cool. I was wondering if you were going to install them without
opening up the package. ;=)
Pax,
Ed Holyoke
