IO-240
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
elli1409(at)bellsouth.net
PostPosted: Thu Oct 12, 2006 10:53 am    Post subject: IO-240 Reply with quote
I am also interested in learning more about this engine, since I will be installing it on my Rans S-16 in another year or so. I will tell you what I have learned, with the caution that I am not expert, just passing along my impressions:
1-Be careful with Warp Drive props with this engine. The Rans prototype S-16 experienced delamination problems with Warp Drive. Nothing wrong with the prop, per se, but apparently the power pulses of this engine were causing too much forward/backward stress on the blades. Rans switched to a Sensenich wood prop, which is more flexible in this regime, and the problem subsided. The S-16 is a 150-160 mph cruise airplane with this engine. May not be a problem with other type a/c. Check with prop folks for more/better information.
2-Some parts for the engine are reportedly more expensive than similar parts on other similar size engines. Could be because of low production, compared to O-200, O-235, etc. I also understand the cylinders and other parts are taken from the IO-360 (Continental) design. Again, a somewhat low-production engine. Can anyone verify this?
3-I am looking into the Mattituck non-certified version. Still expensive at about $19,000 vs. 24K for the certified version. Any other sources out there?
4-Not very many used IO-240's on the market. The only production aircraft using it that I know of are the Katana and the Liberty. Any others?
5-There is a reported hard-starting problem with the IO-240, which is rectified by installing either single or dual LightSpeed Engineering electronic ignition module(s). Any experience here?
Good luck with your Kitfox. Again, my information is limited and may not be accurate. If anyone can add to it or correct it, I would be very appreciative.
S-16 Builder
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
donmorrisey(at)hotmail.co
PostPosted: Thu Oct 12, 2006 11:26 am    Post subject: IO-240 Reply with quote
I looked into this engine as well for my BushCaddy R-120 (135 mph never exceed). I ended up opting for a Lycoming O-235, primarily because the engine builder I had selected had only done a half dozen of the IO-240's and I can more than likely get my 110 mph cruise with the lower hp O-235.
He indicated parts were somewhat hard to find and elli1409's email sort of reiterates this. My understanding is that the IO-240 is a good, reliable engine. I would definitely order through Mattituck as they have made lots of them and probably have a good availability of parts.
To: continental-list(at)matronics.com
Subject: IO-240
Date: Thu, 12 Oct 2006 13:53:05 -0500
S-16 Builder
st" target=_blank>http://www.matronics.com/Navigator?Continental-List
p://forums.matronics.com
//wiki.matronics.com
blank>http://www.matronics.com/contribution
All-in-one security and maintenance for your PC.  Get a free 90-day trial! Learn more! [quote][b]
FlyboyTR
PostPosted: Mon Nov 13, 2006 1:23 pm    Post subject: Re: IO-240 Reply with quote
I have a Kitfox (Skystar) Vixen Series 5 with the Continental I0-240. The engine was new and now has 275 hours. The prop is a Warp Drive 70" 3 blade. This past weekend I found cracks on two of the prop collars--close to the hub. Spoke with Warp and was told they would not cover the prop because of the "sharp impulse" the engine has. I've ordered an Ivo 2 blade Magnum in-flight adjustable.
I've had no starting problems with the engine. Just the usual hot start issues because of the fuel injection.
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
