dent in vertical stab skin
Jim Carlton
PostPosted: Fri Jan 27, 2006 4:04 pm    Post subject: dent in vertical stab skin Reply with quote
thanks for the time guys but my research found the answer on Tim Olson's
site...thanks Tim and I KNEW there was an answer out there...just wish I
found it before I dented the skin...and I even read the rest of the plans but
didn't see the reference in the horizontal stab section...
Jim
Tim(at)MyRV10.com
PostPosted: Fri Jan 27, 2006 8:23 pm    Post subject: dent in vertical stab skin Reply with quote
Jim,
Sorry to hear you were late in getting the info. I was irritated
by that one myself. But, now that it's painted it's pretty
much invisible, so hope is not lost.
Question, are you a -10 builder? If so, you should join in
on the RV10-List here on Matronics. Just wanted to make
sure you found your way there.
On the same site you found that tip, I'm trying to keep many
more and when I'm done and flying (maybe 1 month away) I'll
be adding even more to it.
Good luck,
Jim
