Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Se
gerf(at)gerf.com
PostPosted: Fri Jan 27, 2006 7:42 pm    Post subject: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Se Reply with quote
I just got my fuel flow sensor for my AF2500 Engine Monitor and
I'm wondering on the best place/way to mount it.
(The sensor is an Electronics International Inc (Bend, Orgeon)
Model FT-60.)
I'm building a 9 (same fuse more-or-less as the 7). I'm
putting in an IO-320 from Aerosport. Plans have you run the
fuel feed line from the AFP high pressure pump below the tank
selector valve to the firewall between the center floor
stiffeners.
There's not a whole lot of room in there and the latest style
sensor is rectangular block of red anodized aluminum measuring
some 1.25 x 1.25 x 2". I believe the preferred method is to
mount it with the wires exiting the top - which means the
mounting bolts would be vertical.
Anyone out there have experience with this sensor ? Did you
locate it in the cabin floor tunnel forward of the pump ? Did
you bolt it to the floor, or glue it ?
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
dsvs(at)comcast.net
PostPosted: Fri Jan 27, 2006 7:52 pm    Post subject: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Se Reply with quote
Gerry,
I used double sided tape. Along with the fuel lines I think it will stay
put. I did have to build a "dog house" over the cut out in the tunnel
cover. Hope this helps.
shempdowling2(at)earthlin
PostPosted: Sat Jan 28, 2006 8:11 am    Post subject: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Se Reply with quote
I have an afp fuel pump in my 6 and think you would not even know if your
sending unit was mounted in front of it. You cant really get your foot in
there anyway.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
