mogas
lhelming(at)sigecom.net
PostPosted: Fri Jan 27, 2006 8:00 pm    Post subject: mogas Reply with quote
What is easy way to determine which airports have autogas aka mogas for planning XC stops?
Indiana Larry, RV7
Painless
PostPosted: Fri Jan 27, 2006 8:24 pm    Post subject: mogas Reply with quote
Check out www.airnav.com
Type in the airport identifier(s) that you need and it will list sevices at
each in regards to what fuel is available, as well as fairly current prices.
Jeff Orear
RV6A N782P (reserved)
Getting close
Peshtigo, WI
Jeff Orear
RV6A N782P
Peshtigo, WI
bhester(at)hopkinsville.n
PostPosted: Fri Jan 27, 2006 10:04 pm    Post subject: mogas Reply with quote
It will also let you say what type fuel you are looking for and show all
airports within so many miles of a specific airport. You should also
call ahead to insure the info is current. We use to have it but no
longer do. I think the info still says we do. I know two airports not
far from here that has it. Murray, KY and Springfeild, TN
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A Slowbuild wings-QB Fuse-XPO360 engine Smile
Jeff Orear
Getting close
Peshtigo, WI
DOUGPFLYRV(at)aol.com
PostPosted: Sat Jan 28, 2006 4:43 am    Post subject: mogas Reply with quote
AIRNAV.COM
DO NOT ARCHIVE
Ed Anderson
PostPosted: Sat Jan 28, 2006 5:01 am    Post subject: mogas Reply with quote
Larry, AirNav.Com has a Fuel Price program. You can use it several ways.
But, it also includes a function that enables you to input your departure
and arriving airport and specify either the fastest or cheapest route. You
can also specify some parameters such as max leg distance, etc. It will
then compute up to 10 routes and give you how much you would save (I presume
over the average price along the route) each route as well as the distance
of each route, etc.
Worth using, but as others have said, sometimes the fuel prices and
availability are not up todate so you should call ahead.
Ed A
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
Charles Heathco
PostPosted: Sat Jan 28, 2006 9:37 am    Post subject: mogas Reply with quote
I have not been able to find Mo-gas on trips, I just settle for 100LL Lean her out and try to burn off the lead before you park it, Charlie Heathco
rv8ch
PostPosted: Sat Jan 28, 2006 10:15 am    Post subject: mogas Reply with quote
Heathco
If you normally run mogas but you have to run 100LL when
mogas is not available, you could put a little "lead scavenger"
in with the 100LL. Here's a good one:
http://www.aircraftspruce.com/catalog/appages/Decalin.php
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
