912S Gremlin, Advice needed and a lesson learne
rjdaugh(at)rapidnet.com
PostPosted: Mon Jan 02, 2006 3:42 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Returning home after a ride, we had just touched down and I noticed some
splashes on the windshield. (This is not good!) Since the temperatures
were all still good, I taxied on over to the hangar and my friend helped me
pull the cowl off.
By this time, we had identified the splashes as anti-freeze. I was
expecting to see some hose connection leaking, but all fittings were fine,
but the cowl above the overflow container was wet with Dexron. All the
fittings were dry. As we watched, the engine cooled and started sucking the
coolant back into the engine. I added between 32 and 39 oz. of 50/50 before
it all quit sucking back into the engine. This took several hours. This
still left the level in the overflow container near the minimum level.
My friend says that I just had too much fluid in the overflow container and
it flowed out as the engine warmed up. I don't buy this because; 1) I
haven't added anti-freeze over the whole 87.2 hours of flying prior to this
happening. 2) If this was just normal expansion, I would not have had to
add any additional coolant as the engine cooled. 3) I don't think it would
have put coolant all over the top cowl above the overflow container -
Although the air flow in the cowl may splash it around a good bit.
Anyway, I feel that somewhere (one head?) something was hot enough to boil
the coolant and that is what blew stuff out the top of the overflow. My
guess is that the flow to one head wasn't up to snuff and that caused the
problem. I have taken the hoses off the bottom of all the heads and blown
air down backwards through the head and can't detect any restriction in any
of the heads. I would feel much better if I could find a reason for this
blooping of coolant.
I should mention that I have a Grand Rapids EIS that tracks the head temps
on two heads - neither those nor the oil temp was too high. About 2.8 hours
of flying time before this flight, I had covered about 1/3rd of the radiator
surface to try to raise temps during winter flying. After doing this, I
climbed to 10,000 ft to watch temps and they were fine as they were for more
than 2 hours before this last flight. I don't think that covering part of
the radiator was a major cause, but of course it could have aggravated the
situation.
Any advice would be appreciated.
Lesson Learned
I was really worried for some time because as the engine was cooling and I
was adding 50/50 coolant, I decided to check the oil level. I was surprised
to see it near the top of the tank and decided that I had found where all
the coolant that I was adding was going. But later found NO coolant in the
oil and the oil level was Normal! (My panic was unjustified!)
Lesson? Check your levels when the engine is hot, so you will know what to
expect. I wish that I knew what the level in the over flow container should
be when the engine is hot.
Thanks for listening and tell me what I may be missing.
Randy - Series 5/7 - 912S
aldaniels(at)fmtc.com
PostPosted: Mon Jan 02, 2006 4:30 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Two things to check. #1 Did you increase the size of the overflow tank
cap vent hole. I don't understand why this causes a problem but was
warned that it might. #2 Check to see if the return hose going to the
water pump shows signs of collapse. We had one that would suck shut when
it got hot and cause coolant to blow out the overflow tank. This
probably is not the problem because it would show up as high
head/coolant temp but check it anyway. On a 7 Firewall Forward if you
use the provided hose I think is in real risk of collapse due to the
bend around the engine mount. I use a molded hose from NAPA that has
solved the problem.
pull the cowl off.
shoeless(at)barefootpilot
PostPosted: Mon Jan 02, 2006 4:47 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Randy,
Do you have cabin heat that uses hot water?
If so, do you have a control valve to turn flow on and off to the heater
core?
It's possible with this type heater to have an air bubble in the system that
has been sitting there waiting for the most inoportune time to work it's way
into the engine. If this happens it would rapidly expand and blow a bunch of
coolant out into the bottle....
You can guess how I know about this...
Best Regards,
Cliff
me
pull the cowl off.
the
before
and
this
would
blown
any
hours
radiator
more
situation.
Lesson Learned
surprised
the
to
should
jdmcbean(at)cableone.net
PostPosted: Mon Jan 02, 2006 8:36 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Randy,
Most likely had an air bubble in the system... another thing to check is
the location of the Overflow bottle.. should be lower then the expansion
tank. Check the hole in the cap as well.. I believe there was a service
bulletin on that issue.
Have a Safe New Year !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
PostPosted: Tue Jan 03, 2006 8:13 am    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Thanks Alan, - I have been watching an incipient kink on the other side of
the radiator. I should be more concerned about the suction side of the
pump. The molded hose is a great suggestion. The size of the hole in the
cap of the overflow tank doesn't make sense to me, but it is the stock cap.
Thanks Cliff, - The air bubble seems to fit all the data. I do have a
heater core in the cabin - it was used last winter and this fall. (?) But
we had been doing some extreme slips.
Thanks Sid, - I plan to spend some more time with that website.
Thanks John, - I think I have the overflow tank in the correct place, and
will investigate the hole in the cap.
This list is great!
Randy
Malcolmbru(at)AOL.COM
PostPosted: Tue Jan 03, 2006 10:04 am    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
U should go to kodiacbs.com mal
kitfoxjunky(at)decisionla
PostPosted: Tue Jan 03, 2006 1:31 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
How cold does it get where you are? How long had the plane been sitting?
I had my plane in storage last year in an unheated hanger. I noticed some
coolant was leaking from the fitting that goes into the cyl head..on more
than one cylinder. Not a lot..just a few drops on the floor. Someone
knowledgeable with snowmobiles told me that is common. A few weeks back I
went out and noticed the same thing. I ran the engine up and kept a close
eye on it. Once it came up to temp it seemed fine. When I put it way
there was no sign of a leak. Went back a few days later when it was very
cold and again noticed some coolant in the same spot.
Sounds like you had a lot more than a few drops showing..so probably not
the same thing..but thought it was worth mentioning.
Anyone else notice this type of thing with the 912 series of engines when
they cold soak for awhile?
Gary Walsh
KF IV Anphib 912S
C-GOOT
www.decisionlabs.com/kitfox
"Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Sent by: owner-kitfox-list-server(at)matronics.com
01/02/2006 06:42 PM
Please respond to kitfox-list
temco(at)telusplanet.net
PostPosted: Tue Jan 03, 2006 1:57 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Mal
Not sure what you're driving at here --- tried to access the site you
mention and no go. Could you explain further. Thanks
Ted
Edmonton, Ab
DO NOT ARCHIVE
----------------SNIP---------------
Subject: Re: Kitfox-List: 912S Gremlin, Advice needed and a lesson learned.
kirk(at)mninter.net
PostPosted: Tue Jan 03, 2006 8:13 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
I have a pan under my Kitfox. The water pump leaks a small puddle when it
gets cold. When I run up the engine and the seals heat up, no more leak.
After a day or two in cold weather, same thing. It has been like that since
I got the plane running in 2000.
Kirk Martenson
Classic IV Rotax 912 UL
jimshumaker(at)sbcglobal.
PostPosted: Tue Jan 03, 2006 11:16 pm    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Gary
PostPosted: Wed Jan 04, 2006 5:53 am    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Gary,
I haven't noticed any leaking at where the fittings go into the heads. How
do those fittings go in? Are they cast in?
I have had problems with the screw type hose clamps. I tighten them in warm
weather and they work great, but when it gets cold (teens F here) they all
seem loose and some dribble a bit. I tighten them and then when warm
weather returns the rubber in the hose expands and the clamps really cut
into the hose. - The clamps seem too tight at that point. I don't see any
of this type behavior with the spring clamps supplied by Rotax. Perhaps
they can expand and contract to keep the right compression on the hose.
But this is different than my most recent problem. I lost a quart of
coolant in short order in what ever happened.
Randy
lcfitt(at)sbcglobal.net
PostPosted: Wed Jan 04, 2006 7:27 am    Post subject: 912S Gremlin, Advice needed and a lesson learne Reply with quote
Kirk,
I talked to a Rotax Rep about the same problem and they suggested BarsLeak.
I tried it and it worked.
Lowell
