SL-30 side tone problem
rv8striker(at)hotmail.com
PostPosted: Sun Jan 29, 2006 6:14 am    Post subject: SL-30 side tone problem Reply with quote
Anybody have any ideas about what's going on? My avionics have worked like a charm until about two flight hours ago. The side tone on my SL-30 went from normal, to incredibly loud. It still transmits and receives well, but the side tone is so loud, it's uncomfortable. It's installed as the second Nav/Com, number one is a 300XL, it works great.
Steve Struyk
RV-8, N842S
St. Charles, MO
18.8 Hrs (still grinnin')
dan(at)rvproject.com
PostPosted: Sun Jan 29, 2006 6:51 am    Post subject: SL-30 side tone problem Reply with quote
It's adjustable via the system menus (the manual covers it). Try adjusting
it first, but if you have to crank it way down, like below 20, you might
have an audio panel issue (assuming you have an audio panel).
)_( Dan
RV-7 N714D
http://www.rvproject.com
shempdowling2(at)earthlin
PostPosted: Sun Jan 29, 2006 8:58 pm    Post subject: SL-30 side tone problem Reply with quote
Are both radios on the same freq? Sometimes this will cause all kinds of
wacky results.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
