Allegro 2000 ELT Antenna Location
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
hgmckay
PostPosted: Thu Dec 14, 2006 6:13 pm    Post subject: Allegro 2000 ELT Antenna Location Reply with quote
Gentlemen:
<![if !supportEmptyParas]> <![endif]>
My communication radio antenna for my Allegro 2000 is mounted on the centerline of the fuselage aft of the bulkhead that is just behind the seats. Since the fuselage of the Allegro 2000 is a fiberglass composite construction, I have used aluminum tape in an “X” pattern on the inside of the fuselage to obtain a ground plane for the antenna. My ECK Model E-01 ELT unit requires its antenna to be mounted at least 5 feet from any other radiating antenna. Practically, this means that the ELT antenna has to be mounted some where on top of one of the wings using the aluminum as its ground plane. I am wondering where some of you have mounted your ELT antennas.
Hugh McKay
Allegro 2000
Rotax 912UL
N661WW
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
Thom Riddle
PostPosted: Fri Dec 15, 2006 5:12 am    Post subject: Allegro 2000 ELT Antenna Location Reply with quote
Hugh,
Our Com Antenna is located in the same place your is. Our ELT is
mounted on the baggage compartment removable floor between the aileron
control and the flaps control as far forward as possible. That might
not be quite five feet away from the Com Antenna but they both work
very well. The Icom A-200 Radio works great and I know the ELT works
because we accidentally bumped the switch to on and got a call later
from the Search and Rescue folks. AND it was inside a completely closed
metal hangar! It is a good location because you can reach it in flight
if necessary.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
hgmckay
PostPosted: Fri Dec 15, 2006 7:17 am    Post subject: Allegro 2000 ELT Antenna Location Reply with quote
Thom:
I understand where you have located the actual ELT Transmitter unit, but
where have you mounted its antenna?
Hugh
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
