lee.logan(at)gulfstream.c Guest
Posted: Tue Jan 31, 2006 6:25 am Post subject: Titan Cylinders |
Okay, I'll start this off! I'm looking for cylinders for my IO-540
project. If anyone can steer me to a source of good, rebuilt 540 cylinders
(I prefer Titan Cerminil, but will consider others ), I would greatly
appreciate it. There is an AD out on certain serial numbers of ECi's
"classic" cylinders that doesn't apply to the Cerminil. I have a core,
mags, ignition harness, etc. but need cylinders, cam, etc. Help!!
Thanks!
Lee...
| - The Matronics LycomingEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
jball(at)eci2fly.com Guest
Posted: Tue Jan 31, 2006 7:22 am Post subject: Titan Cylinders |
Hi I'm J.B. at ECi,
Please note that the Titan cylinders are new ones that we manufacture
now and are not affected by the AD. The Titan cylinders are available
with either standard steel or Nickel + Carbide ( CermiNil ) barrels.
The Classic Cast cylinders were new ones made here between 1/1997 and
8/2001 that are affected by an AD. They were made with both steel and
CermiNil barrels too. We are offering replacements for affected
cylinders at a discount and with a labor allowance for removal &
replacement.
ECi carries both new and overhauled cylinders for most Lycoming Engines.
The new Titan cylinders that we have now are the parallel valve types,
we are working diligently on the angle valve types and hope to have the
FAA/PMA approval on them by the end of the year. If you have your IO 540
engine model, ( for example; IO 540 C4B5) we can quote both new and
overhauled with the barrel options. We can also overhaul your existing
cylinders. We make cams, lifters, and many other FAA PMA approved new
parts as well.
Kind Regards,
Jim Ball
