"Broken and Garbled" (Additional data)
nuckollsr(at)cox.net
PostPosted: Mon Jan 01, 2007 11:36 am    Post subject: "Broken and Garbled" (Additional data) Reply with quote
At 09:55 AM 12/27/2006 -0800, you wrote:
I have had poor reception from towered airports with my XCOM and now that
my radio is out for repair, poorly received transmissions with my ICOM
handheld A5. I've even tried hooking up my aircraft Comant antenna to the
ICOM but it didn't improve how others hear me (or don't). Could I need
some filter or something? This seriously limits my entry into controlled
airspace so any fix ideas are appreciated.
Ron - RV-4
<mailto:N8ZD(at)yahoo.com>N8ZD(at)yahoo.com
Ron,
Sorry to take so long to get to this . . . the past 10 days
has been wall-to-wall family gatherings so I've been somewhat
pre-occupied.
You need to conduct some tests that do not involve ATC
controllers and other pilots-at-large. My experience has been
that these folks are least able to articulate their perceptions
of radio quality.
Get another hand held and find an avionics technician
or ham radio operator (the grayer the hair the better) and
do some experiments on some frequency not in local usage.
Your cohort in the experiments should be a significant
distance from your airplane . . . 1/4 to 1/2 mile would be
good.
Craft a series of experiments where one thing at a time is
swapped between two conditions. Your experimental cohort
should be able to identify and articulate the differences
between signals that are distorted due to overload and those
that are intermittent. He should be able to identify the
differences between audio that is clipped and audio that
is generally polluted at all levels. He'll also be able to
differentiate between the desired signal (your voice)
and extraneous signals that are products of distorted voice
or other noises.
By process of elimination, you should be able to deduce
which piece of hardware is the focus of the problem and
ultimately deduce and fix its shortcomings. But short of
acquiring and applying some expensive and cumbersome test
equipment, access to an experienced and trained "test ear"
is your fastest path to success.
If I were trying to single-handedly resolve your issues in my
own airplane, I would consider using a pair of low-cost GMRS walkie-
talkies and modifying them to craft a remote receiver for
testing the airplane's transmitters. You could attach headphones
to one walkie-talkie. You might want to power the other
one from larger external batteries. Tape the ptt button down
on the one with fat batteries and rubber-band it to the front
of the VHF hand held so that the antennas point opposite
directions. Set the paired radios up to receive your ship's
transmitter and repeat what is received back to you via the
UHF GMRS hand-helds. It will take a little fiddling with
volume controls but you should be able produce an accurate
real-time sample of your transmitted signal as a remotely sensed
"side tone" in the headphones.
This would let you conduct the experiments in the airplane
and make your own deductions as to cause-and-effect.
< with experiment. >
< --Lawrence M. Krauss >
rparigor(at)SUFFOLK.LIB.N
PostPosted: Mon Jan 01, 2007 12:48 pm    Post subject: "Broken and Garbled" (Additional data) Reply with quote
"I would consider using a pair of low-cost GMRS walkie-
testing the airplane's transmitters."
Hmmm
Free nights and weekend cell/wired/phone/s?
Ron Parigoris
