Pimer tap point 582
Dillfamily(at)sbcglobal.n
PostPosted: Tue Jan 31, 2006 11:04 am    Post subject: Pimer tap point 582 Reply with quote
I am plumbing the fuel system on my model 2 with 582. Is there any important reason why the primer line should tap off downstream of the console shutoff valve?
Jeffrey R. Dill
767JD, M2
(860) 295-8372 home
(860) 985-4315 cell
I
______(_)______
O O
msm_9949(at)yahoo.com
PostPosted: Tue Jan 31, 2006 2:47 pm    Post subject: Pimer tap point 582 Reply with quote
IMHO You want your main fuel shut-off valve to do just that. If primer line branches off upstream of shutoff there will be, in theory, a full time 'wet' line to your engine. Admittedly it's a small diameter line and has to pass thru the primer pump but if pump failed, fuel could possibly drain into carbs with no way of shutting it off.
Jeffrey R. Dill
767JD, M2
(860) 295-8372 home
(860) 985-4315 cell
I
______(_)______
O O
Marco Menezes
Model 2 582 N99KX
Bring words and photos together (easily) with
