TruTrak Pitch Reverse
Tim(at)MyRV10.com
PostPosted: Wed Feb 01, 2006 6:36 am    Post subject: TruTrak Pitch Reverse Reply with quote
Just a head's up on wiring your TruTrak Digiflight II.
I called TruTrak today to verify before I power up my AP servos
if you need to swap wires to change direction on the roll servo,
or if you need to install the pitch reverse jumper. (I wanted
to know for an RV-10 specific install) The answer was "No"
regarding the roll swap, but yes regarding the pitch reverse.
That should save you from having to experiment and then find
it's wrong the first time.
PS: final assy. items are becoming a short list very quickly.
I may have to move that inspection date up. Oh darn. Wink
Tim Olson -- RV-10 #40170
Current section: Final Assembly
DO NOT ARCHIVE
