DAquaNut(at)aol.com Guest
Posted: Wed Feb 01, 2006 10:22 pm Post subject: Main Spar Clevis Pin Safety Pin |
Group,
The safety pin on the main spar clevis pin on my Firefly rotates to where
the point on the safety pin ends up pointing up, even though I install it
pointing down. Anyone else have this to occur? I fold and unfold to fly. I
would feel safer if the pin would stay pointing down . If it came open pointing
up it would have gravity pulling it down. ( and out) . Has there ever been a
case where the safety pins came out of that clevis? Is my concern legit?
Ed Diebel (447 Firefly )
beauford(at)tampabay.rr.c Guest
Posted: Thu Feb 02, 2006 3:51 am Post subject: Main Spar Clevis Pin Safety Pin |
Brother Diebel...
I think a lot of the clevis pins move around some in flight... either to
rotate some,
or slide back and forth some... or both. Mine do... especially on the strut
fittings. The archives should
have a fair amount of material on this subject from past discussion strings
I can remember.
| Quote: | From what I have read, some pin movement is a normal thing, although I have
heard of vibration eventually
enlarging the holes to the point that they required re-drilling and a larger
clevis pin being fitted on high-time planes.
I never heard of an installed safety pin falling out in flight, but I have
heard of clevis pins falling out when someone
neglected to install the safety pin. (As I recall, that incident was not on
a Kolb).
Assuming you used the right size bit to drill yours, there should not yet be
enough slop
to be a problem in your new ship. The clevis pins should be tight enough not
to allow the
attachment fittings to "rattle" yet loose enough to go in easily. If you
are concerned about
yours being too loose, why not call Travis at TNK, describe the way your
clevis pins are moving,
and see what he thinks...?
Personally, I use an AN washer on the clevis under my safety pins just to
make certain
there is never any direct contact between the safety pin and the fittings
should the clevis slide some...
I've heard that quite a few folks do this... I also make a point of looking
closely at the clevis
and safety pins for signs of wear, cracks or unusual grooves every time I
install 'em.
Worth what ye paid fer it... Good luck...
Beauford
FF#076
ul15rhb(at)juno.com Guest
Posted: Thu Feb 02, 2006 4:37 am Post subject: Main Spar Clevis Pin Safety Pin |
Ed and others,
The main clevis pins on the cage moves both ways in flight no matter which way it's installed. I fold my Firestar on every flight and put it in with the safety ring facing front so I can see it. I put an AN nut that fits over the pin to take up the slack.
On the subject of the pins wearing or the fittings widening over time, I have not noticed this on my plane. I inspect this often, and mine are very tight after 19 years of flying.
Ralph
Original Firestar
19 years flying it
-- DAquaNut(at)aol.com wrote:
Group,
Try Juno Platinum for Free! Then, only $9.95/month!
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Thu Feb 02, 2006 4:39 am Post subject: Re: Main Spar Clevis Pin Safety Pin |
| DAquaNut(at)aol.com wrote: | Has there ever been a
case where the safety pins came out of that clevis? Is my concern legit? |
Ed and Group,
I have been on the list for 8 years and flying Kolbs for 9.
The only case of that pin comming out that I can recall, was when the pilot left the pin in his pocket. He got distracted by people asking him questions when he set the plane up. Be assured that the rotation is normal.
My concern has always been that the pins are installed, not the position. My most minimal preflight always involves looking at the safety pins.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Steve Boetto
Posted: Thu Feb 02, 2006 4:47 am Post subject: Main Spar Clevis Pin Safety Pin |
In a message dated 2/2/2006 1:23:00 AM Eastern Standard Time,
DAquaNut(at)aol.com writes:
Group,
pointing
a
Hi Ed,
There was a very long thread that I started last year in regard to safety
pins. Try putting your pins in from the Rear. I know that normal aircraft
protocol is that all bolt heads forward but in my Firefly the pins want to walk
forward. That will keep pressure on the head of the pin and maybe they wont rotate
On the other hand, I use a self lock castle nut and AN bolt followed by a
steel AN safety pin (not stainless). This requires about 5 extra min. but to me
it is worth it. Keep in mind that as far as I know, there has never been a
failure of a properly placed clevis and pin on a Kolb. The original design is
quick simple and reliable. I am sure if anyone knows of a failure they will
respond.
Steve
FF#007
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Thu Feb 02, 2006 7:12 am Post subject: Main Spar Clevis Pin Safety Pin |
Guys,
Don't forget the bottom tail wire wing nut and safety pin.
I have heard of the safety pin back there getting popped open by high grass.
So I use a castle nut and safety RING in place of the wing nut and safety
pin.
My $.02
Denny Rowe
Mk-3, 2SI 690-70
Posted: Thu Feb 09, 2006 7:02 pm Post subject: Main Spar Clevis Pin Safety Pin |
In a message dated 2/2/2006 5:51:58 A.M. Central Standard Time, beauford(at)tam
pabay.rr.com writes:
make certain
install 'em.
Beauford ,
That,s a good Idea I think I will use it. Thanks!
Ed Do not archive it!
rlaird
Posted: Thu Feb 09, 2006 7:31 pm Post subject: Main Spar Clevis Pin Safety Pin |
I not 100% sure of this, but I think the washer is a required item if you
get a UL/UL trainer certified as an E-LSA.
-- Robert
On 2/9/06, DAquaNut(at)aol.com <DAquaNut(at)aol.com> wrote:
beauford(at)tam
make certain
looking
install 'em.
Beauford ,
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Fri Feb 10, 2006 4:46 am Post subject: Main Spar Clevis Pin Safety Pin |
The requirements vary by the inspector. Each has his own quirks and
druthers. Mine didn't even ask to se if the engine would run.
-which if it didn't would be a REALLY safe airplane.
He did ask me to put stops on the aileron controls so they wouldn't
interfere at full throw.
I used an FAA inspector who, at the time, didn't charge anything
-cheapskate, BB
On 9, Feb 2006, at 10:30 PM, Robert Laird wrote:
you
-- Robert
> beauford(at)tam
> just to
> make certain
> fittings
> looking
> time I
> install 'em.
> Beauford ,
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Fri Feb 10, 2006 5:29 am Post subject: Main Spar Clevis Pin Safety Pin |
"I used an FAA inspector who, at the time, didn't charge anything"...
Still don't...
DVD
On 2/10/06, robert bean <slyck(at)frontiernet.net> wrote:
-cheapskate, BB
> you
> -- Robert
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
