panel finishing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
Vince Frazier
PostPosted: Mon Feb 19, 2007 9:24 am    Post subject: panel finishing Reply with quote
Another option to finish your panel(and any other flat surface) is to
use sign vinyl. There are some wicked patterns available. One that is
particularly popular right now is carbon fiber. Many nice woodgrains
are available too. Browse through some of the vinyl graphics websites
and take a look.
If you find one that you like, you can order it yourself or I'd be glad
to order it and sell you only as much as you need so you don't waste 9
yards of vinyl. I can always use it elsewhere.
You'd want to apply the vinyl after you're done cutting/drilling the
panel. Then just install your stuff over it.
The vinyls are very durable and will last for 9+ years even outdoors.
It should last the life of your plane if you keep it hangared most of
the time. Even if the vinyl gets damaged, nasty, or the plaid pattern
you chose goes out of style, it is relatively easy to remove by peeling
off with a little heat. Then apply some new and your done. No
stripping, no paint fuems, easy.
Check my website for other graphics. And I sell the world's best
performing Rocket/RV full swivel tailwheels too.
Vince Frazier
Screaming Eagle Graphics and Accessories, LLC
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839
http://vincesrocket.com/products.htm
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
Vince Frazier
3965 Caborn Road
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
