david(at)mcgirt.net Guest
Posted: Mon Mar 05, 2007 4:41 am Post subject: Brain Tease for your morning.. Curry's Paradox |
Description: |
Filesize: |
30.18 KB |
Viewed: |
259 Time(s) |
Posted: Mon Mar 05, 2007 6:59 am Post subject: Brain Tease for your morning.. Curry's Paradox |
The area under the red Right Triangle change the area that the Green and Yellow (or what ever that figure's color is) has to fit into. In other words, even thought the sides are still the same lenght the size of the area under the Red vs Green right triangle increased the area size for the other two figures to reside in. That is as simple as I can get it.
Doc
Description: |
Filesize: |
30.18 KB |
Viewed: |
210 Time(s) |
dsavarese(at)elmore.rr.co Guest
Posted: Mon Mar 05, 2007 7:11 am Post subject: Brain Tease for your morning.. Curry's Paradox |
The three triangles involved have different angles so that their hypotenuses have different slopes.
Dennis
Description: |
Filesize: |
30.18 KB |
Viewed: |
238 Time(s) |
eyeballs(at)cox.net Guest
Posted: Mon Mar 05, 2007 8:57 am Post subject: Brain Tease for your morning.. Curry's Paradox |
the multicolored, red and green tirangles are drawn as though they are proportional. They are not. The large triangles sides have a 2.6 to 1 ration. The red sides are 2.66667 to 1 and the green green sides are 2.5 to 1.
The hyp of one or the other multicolored triangle is not a straight line. The whole thing is an optical illusion.
eyeballs
Quote: | Quote: | From: David McGirt (david(at)mcgirt.net)
Sent: 3/5/2007 6:50:33 AM
Subject: Brain Tease for your morning.. Curry's Paradox
[img]cid:413345715(at)05032007-0e07[/img]
Description: |
Filesize: |
30.18 KB |
Viewed: |
241 Time(s) |
pilko2(at)btinternet.com Guest
Posted: Mon Mar 05, 2007 9:04 am Post subject: Brain Tease for your morning.. Curry's Paradox |
It's based on an optical illusion. The hypotenuse of the large triangle (not a real triangle) is bent in both illustrations.
So the lower is bulging and the upper is sagging, the white square is the difference in areas between the two.
Which is a different way of describing that that has already been said !
Description: |
Filesize: |
30.18 KB |
Viewed: |
221 Time(s) |
jblake207(at)comcast.net Guest
Posted: Fri Mar 09, 2007 3:28 am Post subject: Brain Tease for your morning.. Curry's Paradox |
Very simple. Deuterons embedded in palladium settle at points within the electron orbitals and substantially increase the deuteron collisions thereby causing the ensuing hole.
Respectfully,
Jon Blake
Description: |
Filesize: |
30.18 KB |
Viewed: |
209 Time(s) |
cjpilot710(at)aol.com Guest
Posted: Fri Mar 09, 2007 4:46 am Post subject: Brain Tease for your morning.. Curry's Paradox |
In a message dated 3/9/2007 6:30:36 A.M. Eastern Standard Time, jblake207(at)comcast.net writes:
Well except for the BS ( ) and you spelled "orbital's" incorrectly, real answer is that the red triangle is larger than the dark green triangle, thus when moved to the base of the figure, orange doohickey, needs to move left and down in order to preserve total shape, thus the hole.
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Description: |
Filesize: |
30.18 KB |
Viewed: |
214 Time(s) |
