n85ae
Posted: Wed Apr 30, 2008 6:25 am Post subject: 801 Battery/Ballast Box |
Can any builder's with completed 801's tell me if they found a need to add
ballast to the tail, or locate the battery aft for balance purposes?
I built my Kitfox with a Continental IO-240B and ended up installing a
ballast box in the tail, via the battery access panel, which was a real
bear of a job.
Just getting ready to rivet my fueslage skins on my 801, and trying to
decide whether or not to build in a ballast box, or battery mount in the
tail.
I'll be using a Lycoming O-360 most likely.
Jeff
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
keystone(at)gci.net Guest
Posted: Fri May 02, 2008 8:28 am Post subject: 801 Battery/ballast box |
Quote: | Quote: | Jeff My 801 did not need any ballast. I too installed a O-360. I put the battery with out a box under the right front seat. While I feel my plane is a little nose heavy it is well within CG. Bill WilcoxN801BW350 hrsWorking on other things and not flying :+( | 0 |
n85ae
Posted: Fri May 02, 2008 8:47 am Post subject: Re: 801 Battery/Ballast Box |
Thanks. It's a lot easier to add facilities for ballast if there is likely
a need during the construction process than after so just want to make
sure.
Thanks Much,
Jeff
