#244 Moose done and final inspection complete.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
waterpro
PostPosted: Sat Aug 04, 2012 1:08 pm    Post subject: #244 Moose done and final inspection complete. Reply with quote
Hi All. #244 is all finished and the final inspection went OK.
Only one small issue. The original application to transport Canada (MD-RA) was submitted for 3500 pounds gross.
Since 244 is on amphib. floats that does not leave a great deal of payload as she is a good 2611 pounds empty.
We can apply for an increase to the gross weight after 25 hours of the fly off time but it would be nice to have some weights from the rest of you to give to Transport as proof of the higher gross weight.
She has the Murphy extended wingtips which gives her at least a 5% increase according to Murphy. That should be good to 3675 gross.
In doing the wing loading calculations we should be able to get up to 3775 and still be under the wing loading for high performance specs.
Anybody have a Moose in Canada or Alaska that has been registered with more than 3500 pounds gross?
I know the plane can probably fly just fine at 4000 pounds but we need to know from the rest of you what has been done so we can follow the same path.
Thanks.
Peter
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
tedwaltman
PostPosted: Sat Aug 04, 2012 4:56 pm    Post subject: Re: #244 Moose done and final inspection complete. Reply with quote
Hello Peter and a hearty congratulations!
Bob Patterson (bobp(at)prosumers.ca I believe) can advise you re gross weight.
I do know of at least two folks that have flown at over 4,000 with no problem (albeit at sea level).
Contact me of list and I'll give you at least one of their email addresses.
Ted Waltman
Moose
Denver, CO
tedwaltman(at)gmail.com
aircaper
PostPosted: Sat Aug 04, 2012 6:28 pm    Post subject: #244 Moose done and final inspection complete. Reply with quote
Where are the pictures ? Greg # 300
To: murphymoose-list(at)matronics.com
Sent: Saturday, August 4, 2012 2:08 PM
Subject: #244 Moose done and final inspection complete.
--> MurphyMoose-List message posted by: "waterpro" <h2o.pro(at)hotmail.com (h2o.pro(at)hotmail.com)>
Thanks.
Peter
http://forums.matronics.com/viewtopic.php?ponics.com/Navigator?MurphyMoose-List" target="_blank">http://www.matronics.com/Navigator?MurphyMoose-List<========================
btripp
PostPosted: Mon Aug 06, 2012 6:37 am    Post subject: #244 Moose done and final inspection complete. Reply with quote
We have flown our moose at 4000 pounds on Montana 3500 floats at sea level. It takes between 18 and 20 seconds for takeoff. At lighter weights it's 15 seconds. As usual is quite a trade-off between payload and fuel. Our empty weight is 2990, about 200 pounds heavier than I had hoped, but with six seats we have 150 pounds of seats in the airplane, so just by taking out seats we can save weight.
Bob Tripp
On 8/4/2012 2:08 PM, waterpro wrote:
--> MurphyMoose-List message posted by: "waterpro" <h2o.pro(at)hotmail.com> (h2o.pro(at)hotmail.com)
Thanks.
Peter
http://forums.matronics.com/viewtopic.php?p=380052#380052
waterpro
PostPosted: Mon Aug 06, 2012 4:44 pm    Post subject: Re: #244 Moose done and final inspection complete. Reply with quote
Picture as requested.
http://sdrv.ms/MZs5Ee
aircaper
PostPosted: Tue Aug 07, 2012 5:37 am    Post subject: #244 Moose done and final inspection complete. Reply with quote
Looks great nice paint job, is it the Stewart systems paint ? when are you going to have first flight and will you have a video ? Thanks Greg
Sent: Monday, August 6, 2012 5:44 PM
Subject: Re: #244 Moose done and final inspection complete.
http://forums.matronics.="http://www.matronics.com/Navigator?MurphyMoose-List" target="_blank">http://www.matronics.com/Navigator?MurphyMoose-List<========================
HBaker
PostPosted: Sun Apr 14, 2013 8:42 am    Post subject: Re: #244 Moose done and final inspection complete. Reply with quote
Congratulations! I was wondering if they were PK floats and if they are, do you have any information on the installation which I could use?
Henry SN.: SR 294
Currently building a Murphy Moose - any help would be appreciated.
waterpro
PostPosted: Sun Sep 08, 2013 7:50 pm    Post subject: Re: #244 Moose done and final inspection complete. Reply with quote
The floats are Montana's.
What do you want to know about mounting floats on the Moose?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
