lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Thu May 14, 2009 7:32 am Post subject: Re: M3X pictures,numbers |
pj.ladd(at)btinternet.com wrote: |
Hi Lucien
All that is of course true but in the case of our machines what are we
tallking about...5 mph? How much wear and tear can that produce? What have
you saved .. just a few seconds of rolling time. |
Lot more than that. even in my FSII. If I kept the tail glued to the runway on the roll, I'd lift off around the time the ASI started moving. The difference in terms of wobbling when my wheels weren't balanced too well was significant, not to mention if I wasn't dead on with the rudder.
In the titan, it's literally more than 20mph slower than Vx, with enough back elevator I can get off the ground at somewhere between 40 and 45, even slower if I use about 10 degs of flaps.
Quote: |
As your article states `if you are not up to speed when you try to fly out
of GE you will be back on th ground` I would rather be on the ground for
those extra few seconds and then rotate positively.
Good thread though
Pat |
Er, that's what flying lessons are for . It takes training and practice to learn how to manage a soft-field technique so that you don't do this.
Nowadays, I use soft-field technique on practically every takeoff and the difference in terms of liftoff speed is large.....
LS
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ LS
Titan II SS |
russ(at)rkiphoto.com Guest
Posted: Thu May 14, 2009 7:58 am Post subject: M3X pictures,numbers |
Egad, Pat!
I never had a girl friend cute enough to make me do that!
On May 14, 2009, at 11:00 AM, pj.ladd wrote:
Quote: |
Otherwise you wouldn't ever get fast enough for a takeoff.(in Snow)
Russ,
A very experienced micro flier once told me that one year when
there was heavy snowfall and he couldn`t leave his farm to visit
his girl friend he tied the bumpers from an old car on to his
microlights undercarriage. He said it worked. He was a pretty hairy
flyer anyway
Pat
Dana
Posted: Thu May 14, 2009 9:16 am Post subject: M3X pictures,numbers |
At 10:50 AM 5/14/2009, pj.ladd wrote:
Quote: | ...I would rather be on the ground for those extra few seconds and then
rotate positively.
The whole point of the takeoff run is to get the aircraft up to a safe and
appropriate airspeed for climbout. You do this by reducing drag as much as
possible. For a taildragger, this means raising the tail to reduce wing
drag; wheels have less drag than a wing that's producing lift... unless the
field is soft enough or has grass long enough that it would cause more drag
than the lift induced drag, in which case it would make more sense to
accelerate in ground effect.
In a strong steady crosswind, it may also make more sense to lift off
sooner so the wind isn't trying to weathervane the plane while still on the
ground.
-Dana
OK, I'm weird! But I'm saving up to be eccentric.
pj.ladd(at)btinternet.com Guest
Posted: Fri May 15, 2009 2:43 am Post subject: M3X pictures,numbers |
slower if I use about 10 degs of flaps.>>
Hi,
I am not familiar with a Titan but I had the idea that it was tricycle u/c.
like the Challenger. If that is true then comparison with the Kolb is
invidious. Up elevator on a Kolb on the ground as you know is a waste of
time.
Pat
lucien
Posted: Fri May 15, 2009 5:35 am Post subject: Re: M3X pictures,numbers |
Hi,
time.
Pat |
Wasn't a waste of time in my FSII. Soft-field techique worked just fine for me in it, I could get off the ground at very low speeds, just a little after the ASI started indicating if I'm recalling correctly. I just kept the tailwheel glued to the ground and lifted off in a 3-point atitude.
I recall no struggling just above stall doing it this way, it flew fine in GE at very low speeds. Slowly relaxing back pressure on the stick to stay in GE until fast enough to go ahead and climb out..... Worked fine.....
Again I'd suggest some of those flying lesson thingys to see how this works.....
LS
Titan II SS |
Posted: Fri May 15, 2009 5:53 am Post subject: M3X pictures,numbers |
If I try to force my MkIII off with full back stick it doesn't like
it. There is nothing gained,
it feels lousy and puts unnecessary stress on the tailwheel assembly.
I ease it off with neutral stick, getting into ground effect to pick
up a decent climb speed.
Be gentle with your bird on the ground.
BB
On 15, May 2009, at 9:35 AM, lucien wrote:
> Hi,
> tricycle u/c.
> waste of
> time.
> Pat
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p 44121#244121
Posted: Fri May 15, 2009 6:41 am Post subject: M3X pictures,numbers |
( UP elevator when on the ground)Wasn't a waste of time in my FSII.>>
Of course it was.
A plane changes course by pushing the tail in the opposite direction in
exactly the same way that a boats rudder works. To move up in a plane you
force the tail down. To go port in a boat you push the stern to starboard.
That is why putting the helm over when you are against the harbour wall
doesnt work, and holding the tail on the ground doesn`t work erither.
Of course there comes a point when the AoA eventually produces enough lift
to get airborne but holding the tail down hasn`t contributed anything. It
does ensure of course that you get into the air the moment you have enough
speed, and in CERTAIN CIRCUMSTANCES that may be desirable. I don`t usually
want to do that, I like speed in hand by the time I leave the ground
Cheers
Pat
lucien
Posted: Fri May 15, 2009 8:20 am Post subject: Re: M3X pictures,numbers |
Of course it was.
Cheers
Pat |
Well at this point, and I don't mean to be condescending, but I'd suggest that you get some dual from an instructor focussing on soft-field takeoff techniques.
You're describing as hazardous and useless a mode of flight that is neither and has been employed successfully in fixed-wing aircraft for ages for soft-field ops.
It also works as intended in the Kolb just as it does in any other fixed wing airplane (including trikes) - Kolbs do fine soft-field t/o's without any of the drawbacks you're mentioning here.
PS: you do know that the point of a soft-field t/o is NOT to get in the air as _quickly_ as possible right?
LS
Titan II SS |
Posted: Sat May 16, 2009 1:38 am Post subject: M3X pictures,numbers |
soft-field ops. >>
Sorry Lucien,
I don`t think I have ever said that.
What I DID say was that the take off technique you described was useful `"in
certain circumstances" and " less safe" than the usual method of take off.
If that were not so we would all use that technique all the time.
I think we have flogged this to within an inch of its life and probably
bored the rest of the list silly so I think we should agree to differ.
Whatever our views they have kept us both alive so each must have some
validity.
Cheers
Pat
lucien
Posted: Sat May 16, 2009 7:05 am Post subject: Re: M3X pictures,numbers |
Sorry Lucien,
"in certain circumstances" (soft-field ops) is right but "less safe than the usual method" is _not_ right. That's been my point all along.
Again, some dual with an instructor on soft field t/o techniques, including ground school on the effects of ground effect, etc., is really in order if you think this is the case. Some rough field ops in your plane after that using the correct technique would be a good demonstration of that as well.
LS
Titan II SS |
Posted: Sun May 17, 2009 2:04 am Post subject: M3X pictures,numbers |
"less safe than the usual method" is _not_ right. >>
O Golly Lucien, I thought we had put this to bed. You have cherry picked my
answer. I said `if it was not less safe why don`t we use it all the time."
We dont.
Positively the end.
We have a new and exciting thread to pursue now about the legal
classification of Kolbs.
Cheers
Pat
lucien
Posted: Sun May 17, 2009 9:30 am Post subject: Re: M3X pictures,numbers |
pj.ladd(at)btinternet.com wrote: | "less safe than the usual method" is _not_ right. >>
Well because, with all due respect, you're continuing to say something that's wrong
One last time: we don't use it all the time, NOT because it's _less safe_, but because it's not _necessary_ under all t/o circumstances (i.e. for short fields).
Again, there's _nothing unsafe_ about using GE in soft-field t/o operations in the way we've been discussing. You keep asserting that it is so I keep countering that it is NOT (and offering a way for you to learn that it is not).
LS
Titan II SS |
