tc9008(at)aol.com Guest
Posted: Wed Aug 09, 2006 9:06 am Post subject: Flying without doors |
Has anyone Flown their kitfox without doors?
FLIER(at)sbcglobal.net Guest
Posted: Wed Aug 09, 2006 10:00 am Post subject: Flying without doors |
Flown my IV with'em open, not off, but it shouldn't
make any difference. Flies fine. Lot of breeze!
Just make sure your turtledeck is secure as there's a
lot of pressure on it.
Ted
--- Original Message ---
Subject: Flying without doors
| Quote: | Has anyone Flown their kitfox without doors?
_____________________________________________________
___________________
wingnut
Posted: Wed Aug 09, 2006 10:09 am Post subject: Re: Flying without doors |
Did you do something to secure your doors in the up position? I'd like to try it but my doors are only supported by the lift struts. I was worried that the doors would bang around.
How about flying without a turtledeck?
lcfitt(at)sbcglobal.net Guest
Posted: Wed Aug 09, 2006 10:37 am Post subject: Flying without doors |
Although I have never flown with the doors removed, I have flown with both
doors open and mine open as I take photos. I find that with the doors open,
the doors give a little bit of lift as the nose will pitch up a bit as the
door rises.
Others have much more experience with open door flying and I know there are
listers that routinely remove their doors for summer flying.
Lowell
darinh
Posted: Wed Aug 09, 2006 11:03 am Post subject: Re: Flying without doors |
I have flown with them off and also with them open. Didn't notice a difference between the two. I should mention that these were the bubble doors, not the stock doors.
Darin
n981ms(at)yahoo.com Guest
Posted: Wed Aug 09, 2006 11:04 am Post subject: Flying without doors |
I fly our 6 with doors open occasionally. No extra support is needed but I limit airspeed to less than 80 kts. I had the left door "flutter" once in a descent at about 85-90kts. It was a slow cycle not what I would typically think of as flutter but it went up and down forcefully enough to cause a small crack in the LP bubble door.
Maxwell S6/TD/IO240
wingnut <wingnut(at)spamarrest.com> wrote:
[quote]--> Kitfox-List message posted by: "wingnut"
Read this topic online
Posted: Wed Aug 09, 2006 11:26 am Post subject: Flying without doors |
The doors 'fly' fine when they're open on only the
lift struts.
Subject: Re: Flying without doors
_-
browse
Subscriptions page,
FAQ,
List
| Quote: | _-
(was 2MB)
| Quote: | _-
Web Forums!
| Quote: | _-
| Quote: | _-
Admin.
| Quote: | _-
Michel
Posted: Wed Aug 09, 2006 11:33 am Post subject: Flying without doors |
On Aug 9, 2006, at 8:36 PM, Lowell Fitt wrote:
| Quote: | Although I have never flown with the doors removed, I have flown with
both doors open and mine open as I take photos.
Just like Lowell, I also open a door when I, or my passenger want to
take photos. It may be different from model to model but my Kitfox
model 3 will keep the door open, even if there was no lift struts.
Closing them is not difficult either, it takes a bit of a pull but not
too much. Landing with the doors open doesn't seem to affect the flying
characteristics nor the stall speed, even as the door is pretty close
to the wing.
One thing, though: Try to avoid having loose objects, like maps, etc.
when opening the doors and preferably, don't side slip. Someone on this
list managed to blow off his turtle deck by doing that, if I am not
mistaking.
Also from reading this list and not from own experience, flying without
turtle deck is very much reducing the lift of the plane. Someone else
will certainly explain to you why.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
rjdaugh(at)rapidnet.com Guest
Posted: Wed Aug 09, 2006 11:39 am Post subject: Flying without doors |
Wing nut,
I fly my series 5/7 with doors open. But I do try to limit speed to about 85 mph.
There was a caution on the list a while back to NOT fly without the turtle deck. I don’t have any experience with this, but can believe that is not a good idea.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of W Duke
Sent: Wednesday, August 09, 2006 1:03 PM
Subject: Re: Re: Flying without doors
Maxwell S6/TD/IO240
Read this topic online |
wingnut
Posted: Wed Aug 09, 2006 11:54 am Post subject: Re: Flying without doors |
Cool. This is good news. The heat index in South Carolina has been in the triple digits for a couple of weeks now. I've often thought about flying with the doors up but never had the courage to try it. Maybe now I'll give it a try.. Sheesh, my palms are getting a little sweaty just writing about it...
Posted: Wed Aug 09, 2006 12:28 pm Post subject: Flying without doors |
I actually took the doors off and left them off all summer. I was afraid it would damage the shocks if I didn't . It appears to decend very rapidly but in NC it's a blessing with the heat.
Travis
Posted: Wed Aug 09, 2006 12:30 pm Post subject: Flying without doors |
This post brings to mind a flutter I had early this year. I attributed it
to weak gas struts. I ordered new ones and for the one most often open -
mine, I ordered a stronger strut. No problems since.
Lowell
morid(at)northland.lib.mi Guest
Posted: Wed Aug 09, 2006 12:37 pm Post subject: Flying without doors |
I've never actually removed mine either. They fly just fine opened up so I
never felt a need to remove them. So long as the ball is in the center
there's very little wind.
Deke
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed Aug 09, 2006 1:10 pm Post subject: Re: Flying without doors |
No real time KF experience here - just thoughts.
Doors and cabin breeze
- It might be interesting to clamp on some sort of deflect at the front edge of - like a sun roof on a car.
Turtle Deck
- I'd imagine alot of turbulance as a result of 'no turtle deck' flight. Same wonder as above - might a deflector help windflow and reduce turbulance.
Lost lift must be a result of turbulant.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
Posted: Wed Aug 09, 2006 1:54 pm Post subject: Flying without doors |
There's suction back across the turtledeck from the
lift created by the wings and aft cabin. Coupled
with windblast puts a lot of pressure on the
turtledeck.
| Quote: | turtle deck is very much reducing the lift of the
plane. Someone else
| Quote: | will certainly explain to you why.
Michel
msm_9949(at)yahoo.com Guest
Posted: Wed Aug 09, 2006 2:02 pm Post subject: Flying without doors |
Does it make any difference if only one door is open?
Deke
Marco Menezes
Model 2 582 N99KX
barry(at)pgtc.com Guest
Posted: Wed Aug 09, 2006 3:11 pm Post subject: Flying without doors |
I fly my model IV often with one door open and it is mostly held open by the
slipstream but occasionally trys to close. With both doors open it is just
too windy. I think the open door slows me a bit but not enough to worry
about. I would not fly it with the trutledeck removed.
Barry West
janderson412(at)hotmail.c Guest
Posted: Wed Aug 09, 2006 3:12 pm Post subject: Flying without doors |
I would say...if it works ok flying with doors open then leave it. I've see the result of adding deflectors - spoilers etc on a/c thinking it will help but unless you can wind tunnel test...dont. In this case you might loose the door completely.
Date: Wed, 9 Aug 2006 14:10:24 -0700
--> Kitfox-List message posted by: "Richard Rabbers" <rira1950(at)yahoo.com>
Turtle Deck
Wilson(at)REinfo.org Guest
Posted: Wed Aug 09, 2006 3:16 pm Post subject: Flying without doors |
Bubble Doors? I have been trying to get information on Bubble Doors. What
are they like? Can you send a photo? Did you build them, or did you buy
them? If you bought them, where and how much?
Steve Wilson
kitfoxpilot(at)msn.com Guest
Posted: Wed Aug 09, 2006 3:42 pm Post subject: Flying without doors |
I have the bubble doors on my Model IV, and luv them> you can buy them from
L/P aero plastics.
Ray
[quote]From: "Steve Wilson" <Wilson(at)REinfo.org>
Date: Wed, 9 Aug 2006 17:15:35 -0600
Steve Wilson
