Coastflyer
Posted: Tue Nov 28, 2023 9:30 pm Post subject: Plane Power alternator $$$$ |
Holy cow, my alternator failed (I think) today. I thought “no big deal, I’ll just throw a new one in” but wow, the price has tripled!
I better make sure that is the problem before I spend $1000 on a new one, so I’m looking for some opinions here. Here’s what happened: started seeing intermittent power off indications on the dynon like it was switching to internal battery, then it went black! (Which is strange because it does have a backup battery) Then the radios started to die. I could not see the volts and amps because that is displayed on the dynon (now dark) so I headed back to the airport. After a minute or so the dynon came back and I checked the volts and amps. Volts were around 9.5 and amps were pegged high. My ammeter shunt is in the alternator feed line. I turned off the avionics and other loads, then thought to turn off the alternator. After a while the volts started creeping back up and I was able to use the radio for landing. Volts came back up to 11.5.
I suspect an internal short in the alternator because the battery recovered some after I turned off the alternator. I do have a 60 amp fuse in the alternator feed line and it does not appear to have blown. Maybe the short was not strong enough to blow the fuse?
It is an internally regulated Plane Power alternator about 12 years old with about 600 hours on it.
Any thoughts, opinions, or advice?
Thanks!!!
Jesse
cluros(at)gmail.com Guest
Posted: Wed Nov 29, 2023 12:57 am Post subject: Plane Power alternator $$$$ |
Hi Jesse,
I'd start with downloading the data for this flight from the dynon and posting it here. Then we would know what happened leading up to the incident.
On Tue, 28 Nov 2023, 21:33 Jesse Jenks, <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Jesse Jenks <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)>
Thanks!!!
Jesse
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
Coastflyer
Posted: Wed Nov 29, 2023 6:10 am Post subject: Re: Plane Power alternator $$$$ |
That would be interesting and probably helpful, but I don’t believe the dynon was set up to record data. I’m not a computer guy. It’s an old d180 and I have never done firmware upgrades or played with the data logging features so I assume that was not enabled.
Posted: Wed Nov 29, 2023 10:23 am Post subject: Plane Power alternator $$$$ |
At 11:29 PM 11/28/2023, you wrote:
| Quote: | --> AeroElectric-List message posted by: Jesse Jenks <jessejenks72(at)gmail.com>
Holy cow, my alternator failed (I think) today. Started seeing
because it does have a backup battery) |
At what bus voltage does the Dynon revert to backup
battery?
When was the last time the backup battery was
tested for minimum performance requirements?
When was the last time the ship's battery was
The panel going dark unexpectedly during this
event suggests that it was incapable of supporting
ship's systems for some minimum duration.
I take it you do not have an active notification
of low voltage (flashing light right in front
of your position)?
This suggests that a previously absentee alternator
was awake and working to recharge an essentially
'dead' battery.
Why turn it off? It would probably have started
to reduce output as the battery began to take
a charge . . . how many amps is "pegged high"?
This suggests that the badly depleted battery was
recovering slightly under light load. A voltage of 11.5
on the battery suggests 95+ percent DEPLETED.
| Quote: | I suspect an internal short in the alternator because the battery
recovered some after I turned off the alternator. |
Probably not. The battery was simply struggling
for a second wind while lightly loaded.
| Quote: | I do have a 60 amp fuse in the alternator feed line and it does
to blow the fuse? |
Alternators are incapable of opening their own
b-lead protection except in case of shorted diode(s)
in the rectifier . . . it's always BATTERY energy
that opens this fuse. In this case, battery behavior
suggests near total depletion which would probably
render it incapable of opening the b-lead fuse even
if it were faulted.
| Quote: | It is an internally regulated Plane Power alternator about 12 years old with about 600 hours on it.
Any thoughts, opinions, or advice? |
Take it off and disassemble for inspection of brushes.
I suspect they're worn to the point of intermittent
performance. New brushes may well fix the problem.
Suggest you put your battery on a charger/maintainer
and then do load and capacity checks to assess
minimum performance requirements. You might also
consider testing the backup battery . . . sounds
like it wasn't up to the task either.
Adding ACTIVE notification of low voltage to
your panel would have given you a heads-up
LONG BEFORE this situation degraded into a
tense moment.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
Ceengland
Posted: Wed Nov 29, 2023 11:23 am Post subject: Plane Power alternator $$$$ |
On Tue, Nov 28, 2023 at 11:33 PM Jesse Jenks <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
Thanks!!!
Jesse
| I can hear all the other PP users saying in unison, "Welcome to the club!" The VAF (Van's Air Force) forum has enough threads about PP problems to fill a hard drive. Most will say congrats for getting 600 hours.
Here's a thread about alternator failures, with comparison of PP, B&C, & 'generic'. Note that it is far from scientific; all the numbers for PP will be higher since Van sells PP products with their kits. But it might be somewhat informative that random 'generic' alternators with random installation techniques look about as good as PP.
Here's a recent thread that describes possibilities for repairing your PP alternator. To repair, you need to determine whether the alternator itself is bad, or the regulator inside it has failed. If you want to dig into it yourself, you can get help here with troubleshooting.
There are threads on this list, on the VAF forum, and other places on how to modify most Denso alternators to use external regulation, using either a generic Ford style regulator with external overvoltage protection, or using the B&C regulator with built-in OV protection, low voltage warning, etc. My personal choice has been to use one of the common Denso internally regulated alternators, with OV protection from the B&C OV module (hard to find these days, but you can build one yourself) driving a high current relay in the B-lead path. Bob is currently working on an updated OV module, so that may become an option, as well.
Now, to the unasked question: Why didn't you get an instant notification when the alternator died? You mentioned Dynon, but didn't say whether you have their engine monitor. If you do, you should be able to program an alert for voltage dropping below normal alternator charge voltage. If you don't have the engine monitor, you need some form of low voltage notification so you'll know when the alternator dies. If your shunt is in the B-lead line, and the fault was in the alternator, the current reading should have reversed when you had the failure. If you didn't notice a reversed indication, it wouldn't be surprising; I'd have probably missed it as well in 'the heat of battle'. But if it *didn't* reverse, the fault may well be external to the alternator (somewhere in the a/c's wiring). Worth a look.
If you look through the Z-figures in the AEC book, there won't be any fuses in the B-lead circuit; only 'current limiters' or fusible links. It takes a *lot* of grunt (catastrophic fault to ground) to blow 60 amps of circuit protection, no matter what device is used.
Just some random thoughts; hope some will be useful.
Charlie
_________________ Charlie |
jluckey(at)pacbell.net Guest
Posted: Wed Nov 29, 2023 2:30 pm Post subject: Plane Power alternator $$$$ |
Jesse,
I'm interested in what happened before the incident. Trying to determine the chronology...
1. After engine start did you check volts and amps? If you did, I assume they were normal? What were they?
2. How long were you flying before the problem happened?
3. Did the Dynon backup battery fail, or is it the case that you could have been flying on the backup for a while?
4. Is there a conspicuous indication that the Dynon is running on backup power?
-Jeff
On Wednesday, November 29, 2023 at 11:29:56 AM PST, Charlie England <ceengland7(at)gmail.com> wrote:
Thanks!!!
Jesse
Charlie
Posted: Wed Nov 29, 2023 8:08 pm Post subject: Plane Power alternator $$$$ |
modify most Denso alternators to use external regulation, |
It's not a difficult task . . .
| Quote: | My personal choice has been to use one of the common Denso internally
(hard to find these days, but you can build one yourself) . . .
on an updated OV module, so that may become an option, as well. |
Prototype parts are in hand. I'm going to try
something a little different for soldering the
itty-bitty parts. The tools are at the post office.
| Quote: | If you don't have the engine monitor, you need some form of low voltage
notification so you'll know when the alternator dies. |
We used to offer that too. Maybe that product
should be resurrected as well. All of the parts
necessary to implement a flashing low-volts
driver are already on the board for the
crowbar ovm. Wouldn't take much to shuffle
the parts around.
| Quote: | If your shunt is in the B-lead line, and the fault was in the
had the failure. |
Alternator b-lead readings never 'go minus'
except in case failure of TWO diodes . . . exceedingly
rare. It was the BATTERY AMMETER that
normally manifests minus-zero-plus readings.
| Quote: | If you look through the Z-figures in the AEC book, there won't
what device is used. |
Correct. Alternators are not capable of opening
their own b-lead protection. Energy that opens
the b-lead comes from the BATTERY.
(o o)
Coastflyer
Posted: Thu Nov 30, 2023 4:57 pm Post subject: Re: Plane Power alternator $$$$ |
Thank you guys for the thoughtful and helpful replies!
The dynon is a D-180 which has all my flight instruments and engine indications on one screen. I have to change pages to see the volts and amps, which I agree is not a good thing but has worked ok until now😁
And no I didn’t install a low voltage warning light on the panel. Shame on me. I will do that now or figure out how to enable the audible alarm function in the dynon.
I don’t know at what voltage the dynon switches to internal battery. I couldn’t find that in the manual just now either. It does it on every power shutdown though so I’m used to seeing the prompt to press a key to continue on backup battery. That message was intermittently popping up on the screen at the beginning of the event and was my first indication something was wrong. But then the screen just wet dark. Maybe intermittent low voltage triggered the 30 second timer and since I didn’t tell it to continue on backup it just shutoff?
Anyway. I feel like the dynon discussion is a bit of a sidetrack from the alternator problem.
Bob, the amps indication is a vertical scale and it was pegged at the top, and I believe it said 99 in red! That’s what made me shut off the alternator, thinking there was a nuclear meltdown in progress.
I honestly don’t know how long this situation was developing for. I had flown for about an hour. I feel like the ship battery was pretty healthy. It’s an odyssey pc680 installed 5 years and 175 hours ago, and gives great engine cranking after recently sitting unmaintained for a few months.
The high amps reading with very low voltage is what made me think internal short in the alternator, and the fact that battery voltage recovered with the alternator switched off. But it sounds like you think it’s a more benign failure.
I’m willing to dig into the alternator if that’s the consensus.
I’ll reread all the replies and answer the questions more thoroughly, but don’t have time at the moment.
Thanks guys!
Posted: Thu Nov 30, 2023 5:09 pm Post subject: Plane Power alternator $$$$ |
Jesse, your D-180 records all the displayed parameters and more in an internal file. There is likely an orange, yellow, and black wire going from the back of your D-180 to a DB9 connector. If you connect a laptop running the free Dynon software to that connector you can download the entire event and then it will be a very simple exercise to look at the voltage and amperage recorded during the entire flight up until the D-180 shutdown. This will make diagnosis simple. In fact, it makes the diagnosis of many engine problems simple and can also be used to detect failing exhaust valves before they fail.
You're recording all this great diagnostic data, might as well save yourself thousands of dollars by using it.
On Thu, Nov 30, 2023 at 5:00 PM Coastflyer <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Coastflyer" <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)>
Thanks guys!
http://forums.matronics.com/viewtopic.php?p=512715#512715
WIKI -
Coastflyer
Posted: Sat Dec 16, 2023 8:49 am Post subject: Re: Plane Power alternator $$$$ |
Update: I finally had time to think about this again. I removed the alternator. It makes some scraping noises when rotated. I took it to a local guy who is reportedly very knowledgeable. He tested it and said the rear bushing/bearing is worn and he can’t rebuild it, so I ordered a new one.
Thank you everyone for the advice here.
Dave Saylor
Posted: Sat Dec 16, 2023 2:01 pm Post subject: Plane Power alternator $$$$ |
You can get the whole brush assembly from Aircraft Spruce. It’s a pretty easy job. It includes the regulator too so you end up with a virtually new alternator.
On Sat, Dec 16, 2023 at 08:52 Coastflyer <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
http://forums.matronics.com/viewtopic.php?p=512793#512793
WIKI -
_________________ --Dave
KWVI |
skywagon185(at)gmail.com Guest
Posted: Tue Dec 19, 2023 3:15 pm Post subject: Plane Power alternator $$$$ |
Aircraft alternators....Suggestion:
If you are stuck with a questionable alternator and need rapid test or service. Take it to a reputable auto electric repair shop, however, never mention that it is from an aircraft. If asked, say it's from your boat, tractor, etc.
All the shops that I know will not touch an aircraft unit due to rules and liability regulations, etc.
On Sat, Dec 16, 2023 at 8:52 AM Coastflyer <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
WIKI -
Coastflyer
Posted: Tue Dec 19, 2023 4:10 pm Post subject: Re: Plane Power alternator $$$$ |
My alternator failed just in time!!!
I thought $1,000 was crazy but they just jacked the price up to $1,500!
WTF?
Coastflyer
Posted: Sat Dec 23, 2023 7:49 am Post subject: Re: Plane Power alternator $$$$ |
So I installed the new PP alternator and test flew it yesterday.
The alternator load seems to fluctuate more than I remember with the old one. For example with all avionics and external lights on, the load fluctuates between approximately 14-17 amps.
This fluctuation doesn’t seem normal, at least compared to my old alternator.
Maybe there has been a change to the regulator in the last 12 years, or maybe my belt is slipping a bit? Any advice?
Posted: Sat Dec 23, 2023 8:24 am Post subject: Plane Power alternator $$$$ |
At 09:49 AM 12/23/2023, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Coastflyer" <jessejenks72(at)gmail.com>
Maybe there has been a change to the regulator in the last 12 years, or maybe my belt is slipping a bit? Any advice? |
Alternator CURRENT cannot truly change without
a variation in LOAD presented by the system -OR-
a similar fluctuation in bus voltage. What's
the bus voltage doing? Suggest you check it with
more than one instrument. Jumpy readings in 1970
were cause for concern before digital instrumentation.
Nowadays, you question/verify the instrumentation
first.
If the regulator is bad, bus voltage will be
similarly 'jumpy' but in very small excursions.
It might require close examination of bus voltage
with an analog voltmeter (small with a short pointer)
to see if the voltage is unstable. Do this
before getting out the hammers-n-saws.
(o o)
Coastflyer
Posted: Sun Dec 24, 2023 7:58 am Post subject: Re: Plane Power alternator $$$$ |
Thanks Bob,
Well, I did note several .1 volt fluctuations as displayed on the Dynon…
Posted: Wed Dec 27, 2023 10:05 am Post subject: Plane Power alternator $$$$ |
Thanks Bob,
Well, I did note several .1 volt fluctuations as displayed on the Dynon… |
the significance of this observation is not
a 'given'. Digital displays may exhibit
some 'jumpiness' in the least significant
digits in spite of a rock solid stimulus.
This characteristic is the result of response
times, a/d converter performance and environment
for which the instrument is intended.
Laboratory grade instruments are not expected
to be fast while stability is valued. Field
instruments tend to be faster . . . but
more jitter.
A 0.1V fluctuation COULD be a driver for
the current fluctuations you observed . . .
depends on a number of system variables
most important of which is battery internal
resistance.
But if none of the illumination in the
cabin fluctuates in sympathy with the
current readings, I tend to think that
the readings are an artifact of measurement
technology.
I've got a constellation of tools suited
for ferreting out root cause of your
concerns. Yeah, the 'numbers' are intellectually
irritating but you've not described any
indication that something needs fixing.
I've oft suggested that ammeters are a
tiny step above useless in the operation
of your airplane. All loads are
known and critical components your
management of energy in the design
phase.
After that, airborne operation of the
electrical system should require no
analysis/diagnosis/decisions based on any
condition other than LO VOLTS. From
there, it's implementation of a proven
change of configuration . . . Plan-A,
Plan-B, perhaps a Plan-C.
(o o)
Coastflyer
Posted: Thu Dec 28, 2023 5:40 am Post subject: Re: Plane Power alternator $$$$ |
I ordered a new battery. I figured it’s time to replace it anyway and maybe if battery internal resistance is the cause of the fluctuations I’m seeing, that will clear it up.
Posted: Thu Dec 28, 2023 11:34 am Post subject: Plane Power alternator $$$$ |
Alternator fluctuations....By any chance do you have flashing strobes or something like that type of load..?
That will make your amp meter flicker....
On Thu, Dec 28, 2023 at 5:43 AM Coastflyer <jessejenks72(at)gmail.com (jessejenks72(at)gmail.com)> wrote:
http://forums.matronics.com/viewtopic.php?p=512965#512965
WIKI -
Posted: Thu Dec 28, 2023 8:47 pm Post subject: Plane Power alternator $$$$ |
I'm sorry . . . the battery condition that
promotes hyper-active ammeter indications
is LOW internal resistance characteristic
of a battery in excellent condition. If
this is indeed root cause of your observed
condition, a new battery will only make
it worse.
That's only one of the possible causes.
As I mentioned in the former post, I
your airplane were in my shop, I have
the equipment necessary to deduce
the root cause but it's a pretty
detailed investigation. I was pretty
wordy in that missive. Short answer:
I don't think there are any operational
concerns that arise from your
observations.
(o o)
