bruce.smith(at)york.com Guest
Posted: Thu Apr 06, 2006 3:59 am Post subject: Grumman strength |
Gary, and fellow Teammates,
What is it that goes into determining the Vne of an airplane? Is it
shear (brute?) strength alone, or aerodynamics, or a combination of
factors. The Cheetah I fly has a Vne of 190 mph, where a Piper Archer is
redlined at 174 mph.
Slow day again, so I thought I'd ask. Gary, any amusing annuals lately?
Thanks.
Bruce Smith
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
flyv35b(at)ashcreekwirele Guest
Posted: Thu Apr 06, 2006 6:57 am Post subject: Grumman strength |
Certified aircraft are required (FAR Part 23) to be dive tested (design dive
speed) to 10% above what the manufacture sets as Vne. For the Tiger that
would amount to about 220 mph. As far as I can determine this is and has
always been based on IAS. But read the article by Van's chief engineer
about their "theory" that Vne is and should be based on TAS. Quite
interesting but I don't know if this has been subscribed to in any
aerodynamic texts (Gary should be able to shed some light on this).
http://www.vansaircraft.com/pdf/hp_limts.pdf
This doesn't mean that flutter will automatically occur at the design dive
speed, just that the plane was tested up to that speed and the controls
excited and there wasn't any catastrophic flutter. But don't forget that
this was with a new plane with tight controls, cables adjust properly and no
wear in the trim linkage. And Lord knows I have seen a lot of Grummans with
quite a bit of elevator trim linkage, much more than a new plane would have.
Cliff A&P/IA
GrummanDude
Posted: Thu Apr 06, 2006 12:34 pm Post subject: Grumman strength |
In a message dated 4/6/06 7:57:57 AM, flyv35b(at)ashcreekwireless.com writes:
Quote: | This doesn't mean that flutter will automatically occur at the design dive
excited and there wasn't any catastrophic flutter.=A0 But don't forget that
this was with a new plane with tight controls, cables adjust properly and=20no
wear in the trim linkage.=A0 And Lord knows I have seen a lot of Grummans=20with
OFF-THE-RECORD: I know of one Cheetah that did a split-S at 12,000 feet and
leveled off at 3,000 feet. At or near 200 indicated for a good portion of
the way down. Smooth as silk.
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
923te(at)cox.net Guest
Posted: Thu Apr 06, 2006 1:51 pm Post subject: Grumman strength |
I thought you all might be interested in Fred Kokaska's comments when I ask
him a similar question concerning Vne for teh 540 powered Tigers:
Fred:
"I went through the Vne part of certification at 100% of Vne for an AA5B
(174 KIAS), There were two Part 23 objectives in this flight test (flown by
FAA test pilot) of verifying the prop does not overspeed (above 2700 RPM) at
Vne. .... The other was pitch and roll control and airframe vibration.
The test pilot started at 10 K feet and pushed over at full power to
establish 174 KIAS, did some 30 degree left and right rolling maneuvers. He
commented (and I looked out the right side) on the fact the ailerons were
both about 2 inches above the normal even with the flap position in level
flight from airloads. While this looks spooky, he noticed no binding or
control input problems that he did not like."
I think the aileron flexing is a bit unerving.
Best Regards,
Ned
Posted: Thu Apr 06, 2006 2:13 pm Post subject: Grumman strength |
Quote: | I think the aileron flexing is a bit unnerving.
Best Regards,
Ned
Apparently due to the high airflow over them and stretch of the cables or
deflection in the system. I guess that is the position they want to seek at
high airflow. Any flight at Vne can be a bit unnerving.
Cliff
A1ynk(at)aol.com Guest
Posted: Thu Apr 06, 2006 3:01 pm Post subject: Grumman strength |
The aileron flexing is in the torque tube. It is meant to flex. That is how
you get the 15 degrees up travel and 7.5 down. The aileron hits the stop and
then the torque tube flexes alowing the other aileron to go up and hit that stop.
Bill Hatton
N9965U
gilalex(at)earthlink.net Guest
Posted: Thu Apr 06, 2006 8:48 pm Post subject: Grumman strength |
Don't forget the one that had aileron flutter at Van Nuys....
The photo of the 'bent' wing was quite scary, but nice to see the spar
could bend without breaking.
They lost their counterweights in wake turbulence while on downwind.
It was on a FAA poster at WJF - I'm sure Gary remembers it.... I think it
got the aileron AD started....
gil in Tucson
and=20no
Grummans=20with
have.
GrummanDude
Posted: Thu Apr 06, 2006 10:26 pm Post subject: Grumman strength |
In a message dated 4/6/06 4:02:18 PM, A1ynk(at)aol.com writes:
stop.
Bill Hatton
Not true. To go past the stop on the left side you are actually stretching
the cables so the right aileron hits its stop and vice versa.
AuCountry Aviation
GrummanDude
Posted: Thu Apr 06, 2006 10:28 pm Post subject: Grumman strength |
In a message dated 4/6/06 9:49:39 PM, gilalex(at)earthlink.net writes:
Quote: | Don't forget the one that had aileron flutter at Van Nuys....
Well, it did NOT have aileron flutter. And, it happend a LONG time after
the AD came out.
I looked at that Tiger to do an estimate on repairs. The ailerons had been
installed wrong. The long bolt that goes through for the aileron stop had
been installed outboard of the stop. Thus, (don't you just love that word) the
aileron stop could not act as a stop. The plane had encountered (or so the
pilot said) wind shear from a jet landing on an adjacent runway. As the
story goes, the pilot tried to correct for the roll and the aileron ripped out.
Funny, but the aileron stop was still there and intact. The other aileron
was still on the plane and the aileron counter-weight had made a mark in the
wingtip where it had gone way past the design limit.
Gary
AuCountry Aviation
Posted: Fri Apr 07, 2006 3:43 am Post subject: Grumman strength |
Cliff, Gary,
So, Vne is calculated, and then tested, right? Based upon spar strength,
fuselage material strength?
Did the factory ever do a static test to destruction? It would be
interesting to learn what the ultimate load factors were, just for
conversation and bragging rights.
Gary, OK how much is the Cheetah annual costing right now?
Bruce
TeamGrumman(at)aol.com said the following on 4/6/2006 4:31 PM:
Posted: Fri Apr 07, 2006 4:46 am Post subject: Grumman strength |
Agreed. The torque tube is pretty rigid and deflects very little. And the
amount of deflection upward after the opposite aileron hits its stop seems
to vary from plane to plane and appears to be less than the difference in
travel between the two (7.5 degrees), although I haven't measured it
specifically. Due to tolerances in travel and rigging there can be quite a
difference here.
Cliff
Posted: Fri Apr 07, 2006 5:05 am Post subject: Grumman strength |
The aileron got started years ago off the east coast, on a plane coming back
from the Bahamas I think. I understand that it consisted of a mild
amplitude oscillation of a couple of cycles per second, probably the same
phenomenon that many owners have experienced at times when flying in rain
and otherwise. Initially, the FAA wanted to truncate all the ailerons at
the trailing edge as a solution and the AYA and owners interceded and
allowed the alternate solution of the 100 hr inspection which most everyone
has opted for since.
I bought a really nice 79 Tiger from an insurance company years ago that was
declared unairworthy primarily due to this oscillation by an owner who
wanted to get rid of the plane and he found a young new IA who was ignorant
and agreed to go along with the idea. The insurance adjusted never came out
and look at the so-called damage! The story is a bit more involved but the
bottom line was I flew the plane after installing all new aileron bearings
and adjusting the cable tension and the oscillation still existed just
before the stall buffet while creeping up on it slowly from a slow flight
condition. It is nothing serious to worry about. Later on after removing
and balancing the aileron to dead on (it was within tolerance before) the
oscillation completely disappeared. I sold the plane a year later after
flying it all over for 100 hrs for $26,000 more than I paid for it!
Cliff A&P/IA
Posted: Fri Apr 07, 2006 6:14 am Post subject: Grumman strength |
Gary probably knows more about this than I do, but I think that Vne is more
based on the aeroelasticity of the control surfaces and their attachment
structure that it is on ultimate strength. Factors such as balance, control
surface and system rigidity and design of the control surface itself are
more important than brute strength. Of course you also want the strength in
adverse situations such as rapid aileron deflection, maybe to the stops, at
reasonable speed. That doesn't mean that you can go to Vne or almost and
then do maximum aileron deflection at the same time. This would add a lot
of load to the wing with the down aileron, not to mention the forces on the
aileron itself. This is exactly what has happened with the T-34 Beechcraft
during the mock combat flying during a dive and rolling severely while
"chasing" another plane. The plane was never designed for these
"combination" loads at the extreme edge of the envelope. Full aileron
deflection is not all that hard to do for a short time, even without doing a
roll, by starting in a steep bank one direction and rolling the other way
with full opposite aileron for about 3 seconds. Don't try this at speeds
above maneuvering speed.
Don't know what the factory did regarding static load testing. I'll bet
they never went to failure on the wing. My concern with overload would not
be with the wing but with the tail, especially on the AA5A and B.
Cliff A&P/IA
Posted: Fri Apr 07, 2006 6:21 am Post subject: Grumman strength |
This makes me believe that the critical part of the aileron system and
inspection per the AD79-22-04 is the integrity of the balance weight and the
outer aileron bracket. Both of these areas can be inspected pretty well on
even a preflight with a good strong flashlight if you know where to look.
Any crack in the radius of the aileron bracket or in the weld joint of the
balance weight is cause for immediate replacement. I have seen a few outer
aileron brackets cracked but no balance weights.
Cliff A&P/IA
GrummanDude
Posted: Fri Apr 07, 2006 10:22 am Post subject: Grumman strength |
In a message dated 4/7/06 4:45:14 AM, bruce.smith(at)york.com writes:
Quote: | Gary, OK how much is the Cheetah annual costing right now?
Bruce
let's just say that the prop had crackes in the hub, an ADF was removed, the
dorsal fin was replaced, the windshield was replaced, a top overhaul with new
Lycoming/Lycon prepared cylinders, painted firewal, lots of powder coating,
JPI with fuel flow, new hoses, new engine mount isolators, complete annaul, new
brakes, repair of brake line, two wheel bearings, and lots of odds and ends.
So far, it's almost 70% of the cost of the plane (he bought it in Nov 05.)
AuCountry Aviation
GrummanDude
Posted: Fri Apr 07, 2006 10:26 am Post subject: Grumman strength |
In a message dated 4/7/06 7:15:20 AM, flyv35b(at)ashcreekwireless.com writes:
Quote: | Don't know what the factory did regarding static load testing.=A0 I'll bet
they never went to failure on the wing.=A0 My concern with overload would=20not
I had heard that the Cheetah that encountered the thunder storm was tested
and it took something like 16 to 20 g to bend the wings.
AuCountry Aviation
GrummanDude
Posted: Fri Apr 07, 2006 10:28 am Post subject: Grumman strength |
In a message dated 4/7/06 7:29:10 AM, flyv35b(at)ashcreekwireless.com writes:
Quote: | This makes me believe that the critical part of the aileron system and
How about an aileron bracket that uses the same bearing as the one inside the
outboard flap bracket? That would eliminate a good portion of the wear on
the outer aileron torque tube.
AuCountry Aviation
Posted: Fri Apr 07, 2006 10:36 am Post subject: Grumman strength |
So, you're preparing a "Better Than New Cheetah" for him or her.
TeamGrumman(at)aol.com said the following on 4/7/2006 2:20 PM:
> Bruce
Posted: Fri Apr 07, 2006 11:35 am Post subject: Grumman strength |
Like I said, I wouldn't worry about the wings. Maybe the tail isn't of any
concern either.
Cliff
Posted: Fri Apr 07, 2006 11:37 am Post subject: Grumman strength |
That would be an improvement and preclude the expense of installing the
stainless steel wear sleeve and oversize bearing. There is plenty of room
for a wider bearing it seems to me.
Cliff
