clint_bazzill(at)hotmail. Guest
Posted: Sat Jul 01, 2006 7:57 pm Post subject: 912s vs. Jabiru 3300? |
I have flown in a 2200, 3300 and probably have the first 912ULS engine in a Model IV 1999. Find someone who has these aircraft with these engines and go for rides with them. Don't listen to all the Bull thats thrown around. I would find it difficult to find some one in a kitfox that can out perform me, except in speed. I have the 800/6 6 ply tires and tundra tail wheel. Likle I said, it would be cheap insurance to buy an airplane ticket to almost anywhere and fly with some one to check it out. Again my 2 cents worth. I have a start up and shut down procedure that is smooth as glass. You can do some serious damage to a 912 S series engine if your not carefull. With certified ones too.
Subject: Re: 912s vs. Jabiru 3300?
Date: Sat, 1 Jul 2006 20:40:34 -0700
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
clint_bazzill(at)hotmail. wrote:
| Quote: | MY 3 cents worth now.? Again, ride in the airplane with the 3300 and then with the 912ULS.? You will get your answer in a hurry.? The 3300 is 200 cubin inches, same as a 0200.? figure it out.? ? Clint? PS don't forget your earplugs.
Clint,
I don't quite follow, are you saying you think it would be a good idea or not? The Jab may be 200 cubes like the 0200 but it has 20 more horses and weighs about 25 to 30 lbs less. I
darinh
Posted: Sat Jul 01, 2006 8:43 pm Post subject: Re: 912s vs. Jabiru 3300? |
Ok, thanks for the clarification. I would love to fly in any Jabiru powered Kitfox but so far, I believe Michel here on the forums is the only one I know with the Jabiru and he is in Europe. I have flown in an IO-240 powered Series 5 and it was great but not my choice due to weight...it weighed in at around 950 lbs or so. The only engines I am considering are the 912s and the Jab 3300. Like I said, I had a 912UL in my last Fox and loved it (by the way, my start up and shut down were equally as smooth) but have yet to fly behind a 912S. If I were building a Model IV, there would be no question but it is a hundred pounds or so lighter than the 7 and was not designed for the cruise that the 7 was designed for (that is not to say it won't cruise along with a 7 with the right prop and engine combo). It is my understanding that the 7 was built with the 914 in mind and thus the much higher cruise speeds. Well, the 914 is definately out of the question due to outrageous cost but more than cost is the complexity of the turbo (I like the KISS approach). I simply want to have a few more ponies than 100 so I can get a bit more cruise out of the airplane...and at the same time keep the weight in a reasonable range to allow for good shortfield performance (300' or so ground roll area). I know the Rotax will do the trick in the short field category but is a bit slower in cruise. I don't know if the Jabiru will fit both of the cruise and short field scenarios, hence the post to see if anyone does.
Thanks guys,
Darin
Michel
Posted: Sun Jul 02, 2006 12:20 am Post subject: 912s vs. Jabiru 3300? |
On Jul 2, 2006, at 6:43 AM, darinh wrote:
| Quote: | I believe Michel here on the forums is the only one I know with the
.. but you're still welcome to visit me in Norway, Darin! If you take
an airliner to Torp ENTO, I can be there to meet you with my Kitfox!
I think both Rotax and Jabiru are fine engines. Much wisdom has been
said in this tread and I have little to add, if it isn't an
observation: Jabiru sells aircraft and engines. If you install a Jabiru
engine on another aircraft, do it as Jabiru recommends. It will be easy
and trouble-free for years to come.
On the Jabiru Yahoo list, those who have had problems are those who
think they know better that the Jabiru engineers and use unorthodox
solutions.
Last; as for any air-cooled engine, the shaping of the cowling is the
alpha and omega of temperature management. You can install a Jabiru
engine in maybe one day, but you may need many days in epoxy and
fiberglass to shape a good cowling.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
darinh
Posted: Sun Jul 02, 2006 11:51 am Post subject: Re: 912s vs. Jabiru 3300? |
Michel,
Thanks for the invite! I have an older brother who lived in Norway for a couple of years and speaks the language fluently. I have always wanted to take a fishing trip there with him so this may be a good excuse. If I get there, I will definately look you up. I appreciate you posts and comments on the Jabiru. The engine is definately a work of art and is simply beautiful being completely CNC machined...if overall looks of the engine were the only judging point, the Jabiru would be it for sure.
About the cowling and cooling issues. I understand that it is imperative that cooling be addressed with any engine and that it may take more effort to properly fit baffling, etc. than it does to install the engine. My understanding is that Jabiru makes a complete FWF kit for the Series 7 and I would expect that they have included any baffling that would be necessary to ensure the engine runs within its limits. I will definately let you all know which route I choose.
Darin
smokey_bear_40220(at)yaho Guest
Posted: Sun Jul 02, 2006 12:42 pm Post subject: 912s vs. Jabiru 3300? |
Darin,
--- darinh <gerns25(at)netscape.net> wrote:
| Quote: | ..... It is my understanding that the 7 was built
speeds......
I think the cruise speed increase was more a function
of "true speed" gained at high altitude with a turbo
than the greater HP. It probably indicated around the
same as other fox's. If you really want that speed,
you need the turbo and to fly high.
Kurt S.
Posted: Sun Jul 02, 2006 3:58 pm Post subject: 912s vs. Jabiru 3300? |
If you want speed, don't build a slow airplane. Clint
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: Re: Re: 912s vs. Jabiru 3300?
Date: Sun, 2 Jul 2006 13:41:45 -0700 (PDT)
--> Kitfox-List message posted by: kurt schrader <smokey_bear_40220(at)yahoo.com>
Darin,
speeds......
you need the
darinh
Posted: Sun Jul 02, 2006 5:36 pm Post subject: Re: 912s vs. Jabiru 3300? |
I agree with Kurt, the high cruise with the 914 was at altitude and I am not going to be cruising at 15k plus so I ruled this engine out long ago.
Clint,
| clint_bazzill(at)hotmail. wrote: | | If you want speed, don't build a slow airplane. Clint |
I think you have misunderstood my use of "cruise speed". I am not looking for blazing speed...I know that the kitfox is not fast and I don't expect it to be (I have owned one before you know, a Model III that cruised at 75 - 80). I am perfectly aware that I am not going to break any speed records in one. That being said, I would like to get as much speed as possible without sacrificing the reason I am building another Kitfox...low and slow, tree-top flying with those short backcountry strips in mind. I have a cabin with a private 1300' one way strip located the Bitterroot mountains (within 100 nm of virtually all the strips in Idaho) that I need to get in and out of. But, I live in Utah and I would love to have a cruise of say 120 - 130ish which would put flight time at approximately 3 -3.5 hours assuming usual winds. I am simply trying to learn if the Jabiru 3300 will provide this type of cruise while maintaining the great short field properties of the Kitfox...if not I will go with the proven 912S.
It sounds like nobody can tell me if the Jabiru will provide me with both, so it will come down to a decision and without any other first hand field experience, I would have to say I would go with the Rotax because I know its performance, which by the way is good enough for me, just always looking and hoping for more.
By the way, if I would have wanted all-out speed, I would have continued with the build of my RV7 but cut that short for another Kitfox because that is where my flying passion lies...on the undeveloped strips of Idaho and Utah.
Darin
Posted: Sun Jul 02, 2006 8:28 pm Post subject: 912s vs. Jabiru 3300? |
I Flew my plane to Alaska and around a little over 904 hours and my fuel burn was a little less then 4.1 Gal / Hour. Our speeds were about 110. I always fly with power back, big wheels etc. Figure 100 Kts TAS. Works out quite well. Don't pay too much attention to rate/minute climb but get there in a hurrry. By the way my plane is a Model IV-1200 with a Rotax 912uls with a 72 inch 3 blade IVO prop. Which almost no one talks about which is pretty cheap, adj while flying. My Trip to Florida I used also about 4.1 GPH. I have flown 8 times to Arizonia and same fuel burn. You are not going to get good results with Props that turn high RPM's to get power with a whimp of a prop. You need some wood out there if you are going to make that engine work. My 2 cents worth. Clint
Date: Sun, 2 Jul 2006 18:36:19 -0700
Clint,
| Quote: | If you want speed, don't build a slow airplane. Clint
I think you have misunderstood my use of "cruise speed". I am not looking for blazing speed...I know that the kitfox is not fast and I don't expect it to be (I have owned one before you know, a Model III that cruised at 75 - 80). I am perfectly aware that I am not going to break any speed records in one. That being said, I would like to get as much speed as possible without sacrificing the reason I am building another Kitfox...low and slow, tree-top flying with those short backcountry strips in mind. I have a cabin with a private 1300' one way strip located the Bitterroot mountains (within 100 nm of virtually all the strips in Idaho) that I need to get in and out of. But, I live in Utah and I would love to have a cruise of say 120 - 130ish which would put flight time at approximately 3 -3.5 hours assuming usual winds. I am simply trying to learn if the Jabiru 3300 will provide this type of cruise while maintaining the great short field properties of the Kitfox...if not!
ThomasTomlin(at)comcast.n Guest
Posted: Sun Jul 02, 2006 10:28 pm Post subject: 912s vs. Jabiru 3300? |
Darin,
Sorry I'm jumping in here late, but I just thought I'd throw in a couple
more comments here.
I'm heading out for a two week vacation on the 4th, so I probably will not
be able to answer
any questions before I go.
I have a 3300 on my IV Speedster.
Yes, I also had some teething problems with it...
Running hot...worked on the baffling.
Oil temp too high/low...worked on the oil cooler scoop.
Not enough speed..changed 60" Jab wood to 64" Sensenich G.A. prop
Cabin heat...still wish I had some...
Fuel burn too high...installed carb economy kit...what a difference!
Is any of this different from any new engine installation???
Probably not, but the knowledge base is better for the Rotax...
for now anyway.
What do I really know......I like it!
Is it the best engine out there???? Absolutely...
Not.
All engines, props and for that matter airplanes are a compromise.
I recently flew from Greeley CO to St Francis KS (150 miles) for the
Stearman Fly-in.
Next day a storm came in, so I flew 30 miles south to hangar overnight.
Next morning back to St Francis to buy fuel.
Those three legs total 210 miles and three warmups from cold.
You should have seen the Stearman drivers face after I'd told him where I'd
been
and the pump stopped at 8.4 gallons....priceless.
I'm probably the guy Murle Williams was talking about that flew to the
desert
Fox fly-in last year. We were three IV speedsters. Theirs were 912ul and
IFA Ivoprops.
Their planes were also much cleaner aerodynamically. I had no wheel pants
and 6.00x6
Clevelands hanging out in the breeze.
Yes, they had to slow down for me and I burned more fuel...a bunch more.
I'd like to make that trek again this year. It'll be cheaper and faster.
What I have is a nice sounding, simple, smooth, and powerful engine.
Theirs can descend quicker...less shock cooling risk and IFA prop is a big
plus.
Their cabins were warm. I'm still fuddling with an ineffective heat system.
I think you know all the other plusses and minuses.
Am I glad I installed a Jabiru?
How about I fly to Utah, maybe in late August and you can see one happy
owner.
Is it the Jabiru engine that makes me so happy?
Heck no...It's because I flying a Kitfox!
And if I could afford it, I'd have a big old thirsty Stearman too....
Tom Tomlin
N5XT
132.3 hours in 13 months...but who's counting?
kerrjohna(at)comcast.net Guest
Posted: Mon Jul 03, 2006 7:16 am Post subject: 912s vs. Jabiru 3300? |
Darin, come to Logan for a first hand look at a Model IV with 912>
John Kerr
[quote]-------------- Original message --------------
| Quote: | --> Kitfox-List message posted by: "darinh"
Clint,
being said, I would like to get as much sp eed as possible without sacrificing
&g |
mike Guest
Posted: Mon Jul 03, 2006 8:05 am Post subject: Re: 912s vs. Jabiru 3300? |
I have to chuckle on the blazing speed thing. I really love the tree top flying, but I generally fly 80 kts (gps) while doing this. When I need the speed, generally flying into spokane international(kgeg) I need as much speed as possible, generally 90kts and with a 400ftmin. decent close to 100kts. I also keep that speed up to the lights, drop off the throttle and touch down long, about 1000ft past the numbers and get right off on the first taxiway, which generally there is a 737 right behind me and touching down or close to it when I get off the runway. Very exciting and blazing speed in a kitfox, very much needed, if you want to call it that.
