janderson412(at)hotmail.c Guest
Posted: Tue Aug 15, 2006 12:12 am Post subject: small file Blank series V weight and balance |
No Mark, I made then out of blade tape. Cut strips 90mmwide and overlapped
about 30mm and stuck together. Then I had a strip approx 135mm wide with a
sticky bit opposite sides on each edge. Cut out holes for the strut mounting
bolts as stuck on while the elevator was in the level position. Clear as
mud, perhaps you can work it out from the picture.
John
Subject: RE: small file Blank series V weight and balance
Date: Tue, 15 Aug 2006 00:39:25 -0400
Thanks John for the pics of the gap seals,this is the way I need to
go.......Did you get this from spruce?
Thanks Mark
